We are still asking: What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Probably last warm (70 degrees) day in Kansas City for the next 4-5 months. So played some hooky from work and did a quick once over with CLR, a scotch Brite and some paste was. Come spring I'll finish the roof and tryout the linseed oil method.
I've also read an old hotrod article where they used Zep floor sealer.
Prepping for new front and back glass/gaskets. POR-15 to the rescue on a some surface rust and about a 1.5 inch rust hole in the upper right. I'm trying the old paper towel and POR-15 trick to reinforce the pinch weld. Will follow up with some high quality seam sealer once its dried and cured well.
Yes, paper towel. When POR-15 came out years ago, I remember watching a demonstration at a Swap Meet where they used both a paper towel & fiberglass mesh.. A friend of mine was working on a small patch in a floor pan. He tried it out on a section he had already cut out. Painted, used a blue shop paper towel, thew it in the scrap pile and it was there for 6 or 7 years later and was just then starting to delaminate. POR isn't UV protected.
Since this was on the windshield pinch weld and only a short section, I felt the paper towel would work fine, followed by a very good quality seam sealer to finish out the shape, and I can install the glass/rubber without issues & leaks.
I sure wouldn't depend on POR-15 for that, whether with a paper towel or fiberglass cloth. If you're going to do something like that, use an epoxy filler like JB Weld (and fiberglass cloth).
Kevin Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com] #2 - '29 Ford pickup restored from the ground up. First car '29 Ford Special Coupe Busting rust since the mid-60's
Like a lot of car guys/gals, I have a few projects. A couple plymouth roadrunners, a GTX, and this oddball 56 Jag XK140 Roadster that used to belong to friends of the family. When I look at the Jags engine that started in 1949 and ended in early 2000's, I think that it is one of the most beautiful inline-6s ever made with an awesome sound. Aluminum head, hemispherical crossflow design, and double overhead cam.
Hard to believe the 216/235's are from the same era.
I have a spare 3.4 liter engine and thought it would be a perfect fit for an AD truck along with a simple 5speed conversion.
Chrispy, GoodOnYou! I used to leave the bonnet open on my '62 E-Type just so I could see that beautiful 3.8 dual overhead cam piece of art. I'll have to ease my way into visualizing a 3.4 in one of our ADs. It'd definitely be one of a kind.
The above said, I trust someone would lean over the fender, give it a quick look and state "yep, my best friend's Dad/Granddad/neighbor/uncle/cousin/brother had one just like it".
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1951 Farmall Super A
