The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (Hotrod Lincoln, 47PUJim, GMJim, 1866yellowboy, 2 invisible), 262 guests, and 3 robots.
Forums60
Topics123,450
Posts996,251
Members44,670
Most Online1,229
Jan 21st, 2020
Image Posting Policy
One ton rear brake springs
#1393788 Fri Jan 22 2021 10:13 PM
Ricster Offline OP
Hi Bolters, I have managed to get my rear drums off and found that one of the brake shoe springs is in two pieces and the other, though still intact is 69 years old. So I am hoping that one of you out there has a pair that I can purchase. They are for 1951 gmc one ton rear brakes I checked some of the on line supply houses and bought a set of 3/4 ton springs only to find that they were the same in all ways except for the length. They were 1/2" shorter. Gently stretched out the one ton Spring length is 7 1/2". The new 3/4 ton spring is 7". I'm looking for two springs of the 7 1/2" length for my rear drum which fits shoes that are 14" diameter and 2 1/2" width. The front shoes are 12" diameter and 2" wide and their springs seem fine
I'm hesitant to try to stretch the shorter spring to "make it work" as one person suggested. Any of you with more experience in this, I could use some advice. Thanks
Ricster
Re: One ton rear brake springs
Ricster #1393882 Sat Jan 23 2021 03:59 PM
Jim Carter lists a brake spring that is the proper length but says it is backordered. Look at his site on line, specifically part numbers ME147 and ME148. You might give them a call to see when they might be available and also call other vendors who may have the same part. Good Luck. Finding parts for these old trucks, especially less common models like the one ton, is part of the experience!
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Lightholder's Dad #1395384 Tue Feb 02 2021 12:38 AM
Ricster Offline OP
Just got a delivery from Jim Carter. Two springs! All excited until I measured them to be 7" long, just like the 3/4 ton spring I received much earlier. Question is DO I DARE? Do I stretch them to work or are these not right? The original one that is intact is actually 1/2 inch longer. Just wondering how critical this is. The picture with two springs shows the longer original spring on top and the new one ton replacement on the bottom with the "barrels" lined up on the left side. The other picture also shows the 3/4ton spring which is the same size as the new one ton spring.
Thanks in advance for any feedback.
Ricster.
Ric
Ricster #1396145 Sun Feb 07 2021 01:04 AM
Ricster Offline OP
Update. New springs are in. Discussion and pics can be seen in Driveline Forum under one ton versus 3/4 ton brake springs. Thanks
Ricster
Ric
Moderated by  John Milliman
