The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (Hotrod Lincoln, FAST55, Lugnutz, Bowtie john, homer52, RdsLessTaken, 1 invisible), 280 guests, and 3 robots.
Forums60
Topics123,449
Posts996,249
Members44,670
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 9 of 16 1 2 7 8 9 10 11 15 16
Re: Ignition problems- 305E V6
Jimmy66 #1394947 Fri Jan 29 2021 10:39 PM
Jimmy66 Offline OP
Ok. Will do. If you have any pointers for safely cleaning engine, I’m game.
Got to stop for today. I’m due somewhere at 5:00 and I’m dirty from crawling under truck for pics. I never did pull plugs to turn by hand because I got remote button, so next time I will clean timing disc, pull plugs and turn by hand as you said. May be tomorrow, may be Monday. Depends on what my gal has going for the weekend. Thanks again guys. I’m trying my best.
Jimmy Deveney
‘66 GMC 3/4 ton pick up
4 speed manual
305E V6
Jimmy66 #1394948 Fri Jan 29 2021 10:40 PM
Sir Searchalot
OK, later.
Watch out for careful drivers!!!
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
Sometimes no nonsense makes sense, in a sense
You can't teach a new dog old tricks.
Jimmy66 #1394972 Sat Jan 30 2021 01:14 AM
Sir Searchalot
Martin, Jerry, et al, What do you think he should do next?
Jimmy66 #1394974 Sat Jan 30 2021 01:44 AM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Check your PMs
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
Jimmy66 #1395498 Tue Feb 02 2021 07:46 PM
Jimmy66 Offline OP
Back at it, cleaned timing disc, I can read all markings. Took plugs out, trying to turn by hand, not having much luck.
Jimmy Deveney
4 speed manual
305E V6
Jimmy66 #1395500 Tue Feb 02 2021 07:50 PM
Sir Searchalot
not much luck doing what?
Jimmy66 #1395501 Tue Feb 02 2021 07:50 PM
Jimmy66 Offline OP
Turning engine by hand
Jimmy Deveney
4 speed manual
305E V6
Jimmy66 #1395502 Tue Feb 02 2021 07:51 PM
Sir Searchalot
plugs out, trans in neutral, socket on crank nut CW
Jimmy66 #1395505 Tue Feb 02 2021 07:57 PM
Jimmy66 Offline OP
Ok. I definitely do not have a socket that size, do you know the size off hand? I can grab one later on the way to work.
Jimmy Deveney
4 speed manual
305E V6
Jimmy66 #1395508 Tue Feb 02 2021 08:01 PM
Sir Searchalot
Don't know, find a bolt or nut that matches or measure or push some playdough on it and measure that.
Moderated by  Hambone
