What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Forums59
Topics128,581
Posts1,041,641
Members46,050
Most Online1,229 Jan 21st, 2020
OP
What controls the stock vacuum wiper motor on a 1954 3100? I have the stock motor and control cable but can't see how to connect it to the wiper motor. Is there an external valve or something?
Finally '54
Do these photos help? [ ebay.com] Click on the image and it will get larger - then scroll through the images, using the white arrows at the sides of each image.
OP
Yes, they help a lot. Looks like someone replaced the original motor with something else.
Finally '54
I believe a 54 vacuum motor is different than other years .
I believe a 54 vacuum motor is different than other years . That is correct The change allows for the different design of the 1954/1955st dash compared to earlier years. I think the location/shape of the the radio/speaker, in particular.
Chevy did offer a 6 volt electric as an option. They are as rare as a fertile dinosaur egg but are out there. Once in a while see one appear on ebay but they do not last long. I have had them over the years but sell as fast as I get them
ppp
You can say/post that again, triplet  (you double-posted) this eBay seller has one left [ ebay.com] (he already sold two). Try a websearch search on "1954 Chevrolet truck 6v electric wiper" (the word G-o-o-g-l-e will not display correctly embedded here - "websearch" gets substituted). There are lot shown - if they are still available (be sure to check for 6v or 12v - to match your system).
You can say/post that again, triplet  (you double-posted) this eBay seller has one left [ ebay.com] (he already sold two). Try a websearch search on "1954 Chevrolet truck 6v electric wiper" (the word G-o-o-g-l-e will not display correctly embedded here - "websearch" gets substituted). There are lot shown - if they are still available (be sure to check for 6v or 12v - to match your system). I checked out the ebay link you posted . That is a retrofit using a new style motor. That is not the original wiper that Chevy offered in 54 . This ebay seller probably has as many as he wants to order or put together . The real deal original is much harder to find.
ppp
Electric wiper motors the pickups was first offered for an option in 54 . Prior to that only vacuum was available. In the last 40 years I think I have had less than a 1/2 dozen off them. 1 in the last 10 years . 0 in the last 5 as most of the old yards have went away. I think they cost about $30.00 as an option in 54 which was quite a bit of money. So not a lot of trucks were offered with it.. So when you figure attrition , trucks getting crushed , etc , they hardly ever appear. Rare indeed.
ppp
