The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (tomctomc), 105 guests, and 3 robots.
Forums60
Topics123,939
Posts1,000,194
Members44,787
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
"Paintless" Dent Repair attempt
#1393798 Fri Jan 22 2021 11:22 PM
I have a few dents in the upper rear cab that will need pulling out, so I bought a small slide hammer and some glue-on tabs used for Paintless Dent Repair. The youtube videos make it seem like it would be fairly easy, but maybe it's the thicker sheet metal used on our trucks. The cab is in primer, but with no access behind the rear panel to bump these out, I thought it might work. I couldn't get the tabs to stick on tight enough to do much, although I did reduce the depth of one by maybe 1/16". I tried sanding the primer to smooth it off, but still couldn't get the tabs to stick tight enough to do much moving of the metal. The glue lets loose either on the primer or the tab. ohwell
My next step is some weld-on studs. I have a couple pairs of small vice grips that I'll weld a nut on to attach the slide hammer.
Has anyone had success with PDR?
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Re: "Paintless" Dent Repair attempt
klhansen #1393808 Sat Jan 23 2021 12:58 AM
I have a similar one and if it is a small dome type dent not to bad but the glue let’s go on small dings
was going to try green stick but it may not come off .A small suction cup for dents may work also .since it is only primer can use slide hammer and tack a washer and pull it .The other spoon type tools are too expensive ,maybe a inner tube between panels and rubber mallet.
kevinski 1954 GMC 9300 Welcome to the virtual Garage
klhansen #1393809 Sat Jan 23 2021 12:59 AM
Yes, I had success on a 2002 Hyundai some years ago with the glue-on and a plunger style. Pretty deep dents too. Come to think of it, the suction cup worked on my wife's 2011 Odyssey as well for a small dent.
However, I had no success on my '94 F150. I tried it on my '49 3600 cab and it didn't even try to budge it without the suction or glue pulling off.
1949 Chevrolet 3/4 Ton - Still Solid.
klhansen #1393818 Sat Jan 23 2021 01:30 AM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
The glue type works fairly well on later model sheet metal but anything made of real metal is a lost cause. Tried it in a couple of spots on my ‘65 Biscayne, no luck.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
klhansen #1393819 Sat Jan 23 2021 01:39 AM
OK, thanks guys. You've confirmed my suspicions that I'll need to go with welding pull pins on.
klhansen #1394299 Mon Jan 25 2021 10:58 PM
I have had some success on thicker panels using the glue to initiate a pull and tapping around the perimeter of the dent with a plastic/rubber or wooden mallet.
klhansen #1394302 Mon Jan 25 2021 11:15 PM
Put up a picture of the dent .you could try a small inner tube between the panels with the glue and the rubber mallet. Worth a attempt ,I had a old outboard with a top tank with a dent and I used air to fill the tank a little and tapped around the dent and got most of it out
klhansen #1394753 Thu Jan 28 2021 07:30 PM
Crusty Old Sarge
Eastwood has this slide hammer with locking pliers, you could probably fab up something like this easily enough. It would work good with your weld on pins.
https://www.eastwood.com/eastwood-locking-plier-slide-hammer.html
Craig
Come, Bleed or Blister something has got to give!!!
59' Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting)
TUTS 59 #1394791 Thu Jan 28 2021 10:46 PM
I recall seeing that before. Thanks.
I think what I'll do is weld a nut that fits the slide hammer on the side of the vice grips. Haven't gotten around to that yet.
I built a jig for welding pins on, similar to Eastwoods setup that goes on the MIG nozzle and holds the pin for welding.
klhansen #1394819 Fri Jan 29 2021 02:03 AM
AD Addict
It looks like the vice grip puller sold by Eastman is simply an adaptor that substitutes the bolt that tightens the jaw and is threaded on the end of the slide hammer. If your willing to sacrifice the vice grip, buy a nut that fits the slide hammer from the local hardware store and weld it to the knurled thumb screw. Might just do the trick!
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Page 1 of 2 1 2
Moderated by  HandyAndy, klhansen
