The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 members (bluedot38, E's51, Robby45, 1 invisible), 95 guests, and 2 robots.
Forums60
Topics125,498
Posts1,013,368
Members45,248
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Proper Headers for a 350 SBC on a 51 Chevrolet / 78 Camaro Clip
#1393373 Tue Jan 19 2021 02:48 PM
ColbyG Offline OP
I am installing a 78 Camaro front clip on my 51 Chevrolet 3100 and I am wondering if anyone has experience with the best headers to fit that setup? I understand that the front clip might not make any difference, but I'm still learning and I also understand that there could be some modifying and bending involved no matter which way I go, but I figured that I would ask.
What headers best fit a 350 small block Chevy on a 51 Chevrolet 3100 with a 78 Camaro front clip (second series)?
Thank you guys!
colby
1951 Chevrolet 3100: Photos [photos.app.goo.gl]
–Engine: 219 to 250 to 350 (waiting to be dropped in)
–Currently: Readying a 1987 S10 frame for mounting the body.
1956 Chevrolet 6400
–Engine: moved the 250 from 3100 - newly installed
–Currently: Adjusting Brakes & Installing New Headlamp Switch
1963 Chevrolet C10 Fleetside
–Engine: EMPTY
–Currently: Sitting in Barn
Re: Proper Headers for a 350 SBC on a 51 Chevrolet / 78 Camaro Clip
ColbyG #1393391 Tue Jan 19 2021 04:59 PM
Header design and fit questions open up a whole can of worms. Unless you're running some sort of custom exhaust system with equal-length header tubes from each cylinder tuned for a specific power gain at an RPM range most street engines never see, headers of any kind just make a fashion statement when the hood is open. They also increase the under-hood temperature and noise level, and roast spark plug wires. Pick whatever looks good to you, and put up with the problems they create. I believe I could outrun anyone who wanted to GIVE me a set of headers for street use. Cast iron exhaust manifolds with the outlet near the firewall on both sides make the most sense for pre-1955 trucks that originally came equipped with a stovebolt six, and until very high RPM ranges are encountered, there won't be a measurable difference in power on a dyno run.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
ColbyG #1393403 Tue Jan 19 2021 07:08 PM
Usually, the problem happens because of steering. I put in an '86 TPI out of a Corvette, which had the Corvette huggers already on them. I welded up the air injection bungs, and had to pie cut one collector to clear the front crossmember. I believe companies like Sanderson Headers make a hugger specifically for a Camaro clip. I just saved a few bucks by modifying an OEM manifold. My goal isn't to try to beat Jerry in a race, but to cruise to the place where I can watch the race. Actually, my goal is to get the carbon monoxide behind me and not seeping in to the cab!
Click on my link below to see some of this stuff of where I've been and where you're going.
ColbyG #1393407 Tue Jan 19 2021 07:17 PM
Crusty Old Sarge
I would just use a header that works with the Camaro clip. If you are using the motor mounts original to the clip you should have any clearance issues.
Craig
Come, Bleed or Blister something has got to give!!!
59' Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting)
ColbyG #1393896 Sat Jan 23 2021 04:57 PM
The “ shorty “ style gives you a lot more flexibility than the long tube type.
Suggest getting powder coated rather than chromed - no rusting or discoloration problems
1940 Chevy KC 1/2-Ton
In the Stovebolt Gallery [stovebolt.com]
ColbyG #1393955 Sun Jan 24 2021 12:11 AM
I just put up some shorty headers in the for sale section smile
51 Chevy 3100 Jigsaw puzzle
69 Camaro SS350 convertible
69 Camaro 327 convertible
ColbyG #1393962 Sun Jan 24 2021 12:54 AM
My experience with this is that I have owned a 2nd gen Camaro, and used Hedman 68600 shorty style headers, they worked great, plenty of clearance.
Moderated by  KCMongo
