The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
25 members (D B Cooper, darthintel, 51 3804, 5 Window 9434, 3 invisible), 207 guests, and 3 robots.
Forums50
Topics122,201
Posts980,317
Members44,173
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1957 1/2 ton steering gear box
#1392302 Tue Jan 12 2021 01:31 AM
Crude K Offline OP
Moderated
Just picked up a 57 big window that was a started project. Elderly gentleman started but didn’t get the chance to finish it. He was trying to do a power steering conversion. Cut off the upper shock mound and attempted to mount the gear box on the outside of the frame. So now I have no steering and what appears to be a cut off arm by the king pin. I really want to put it back to the original steering. Any suggestions on parts or a diagram or picture on how it was supposed to be in original condition. Looks like he cut off the steering shaft with a hacksaw.
Re: 1957 1/2 ton steering gear box
Crude K #1392329 Tue Jan 12 2021 03:34 AM
3B Offline
Hy Crude K, welcome, a word of warning, there are two different lengths of steering boxes/ steering shafts in the 1955 through 59 series, 55 and 56 are longer than the 57 through 59 boxes. It sounds like you will also need a new steering arm as well. Those steering boxes have integral shafts and mast jackets there is no joint between the shaft/mast jacket and the steering box, hope that helps.
Crude K #1392337 Tue Jan 12 2021 04:29 AM
There is a modern power steering box by CPP that mounts in the original location if you are interested, last few days on here. Still would need to replace the J shaped arm.
Ed
3B #1392595 Thu Jan 14 2021 01:18 AM
Crude K Offline OP
Moderated
Thanks. That helps a lot. I am going to try and find the one for the 57-58. I will probably switch to power steering at some point but for now there are more urgent things that need to be done. There is a shop near me that does a lot of truck steering conversions for AD. They might have the parts I need.
Moderated by  SWEET
