The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (KevinW, Noonan, Greg_H, 3B, Organbuilder, 68ironhead), 208 guests, and 3 robots.
Forums50
Topics122,200
Posts980,312
Members44,173
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Production Number
#1392424 Tue Jan 12 2021 09:36 PM
3800GUY Offline OP
Today I found another 1950 1 ton here in Minnesota that was built in the same plant and the same month as my 1950 1 ton. The last four numbers at the end of the ID tags are only a difference of 282 trucks. So I would think that this truck and mine were probably built in the same week (just guessing). Did those numbers include all the different truck models or were they only for 1 tons? If it includes all models, then my 1 ton and the one I found today may have been built close to one another if you just count the 1 tons out of that group of 282 truck. This probably sounds confusing, but I thought it was kind of neat to find a vehicle built numerically so close to mine. Tom
Re: Production Number
3800GUY #1392544 Wed Jan 13 2021 07:58 PM
Good question. I don’t know the answer. But I think the sequence number includes all models.
I have noticed that the stamping of some serial numbers is different front to back: the characters for assembly plant, year, series and month may be larger or different font than the sequence numbers.
Example: 21HS-I 4465. Have others noticed this? That’s one reason I think the sequence number includes all models.
Professional Novice
3800GUY #1392558 Wed Jan 13 2021 09:20 PM
ace skiver
The vehicle serial number is for each series at each plant (subtract 1000 from that serial number - in other words, starting at 1001 from each vehicle assembly plant).
The engine serial number is a sequence number starting at 1001 at each engine plant.
http://chevy.oldcarmanualproject.com/chevyresto/5052.htm
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Moderated by  Grigg
