Major event in Virginia
ODSS Bolters
return from
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the
HOT WASH!
Searching the Site
7 members (klhansen, Gdads51, Hanks custodian, Hotrod Lincoln, 69Cuda, Task Force Dan), 686 guests, and 3 robots.
The Zone
Forums65
Topics123,396
Posts999,088
Members47,264
Most Online1,229
Jan 21st, 2020
#1389924 Sat Dec 26 2020 07:52 PM
Rmcea Offline OP
I have a 1950 gmc 1/2 ton which sat in a barn for 24 years. The truck has high ride height and doesn’t have much bounce in the rear suspension. Is there a chance that the spring bushings are seized and not letting the suspension work. Any suggestions would be helpful
Thank you bob
Rmcea #1389936 Sat Dec 26 2020 09:12 PM
All of the spring bushings have grease nipples grease them up for starters then maybe have someone bounce in the back box as someone looks .Maybee a shock absorber
kevinski
1954 GMC 9300
Rmcea #1389939 Sat Dec 26 2020 09:32 PM
It probably has had leaves added to the rear springs. That was very common back on old farm trucks. I had a 40 1/2 ton that had a whole stack of leaves in the rear springs. The guy used to haul his bull in it. You sometimes can tell aftermarket leaves from the original. The after market leaves are blunt on the ends, often cut with a torch. The original are taped om the ends.
George
1972 Chevy c10 Cheyenne Super
KEVINSKI #1392232 Mon Jan 11 2021 04:51 PM
Rmcea Offline OP
It was a seized shock absorber. Thanks for your help
