EVENTS
Check in for status!
Jump over to the
Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Forums50
Topics122,201
Posts980,314
Members44,173
Most Online1,229 Jan 21st, 2020
 Engine work in Michigan
OP
My 49 3600 (216) needs a new rear seal can anyone recommend a good rebuilder/shop that can handle this without me pulling the engine ? Southeast Michigan is preferable. Thanks !!
 Re: Engine work in Michigan
Jim Hughes in Belleville,mi.is a good shop to use He worked on my 54 and did good work
OP
Thanks Keith ! I will definitely check him out ๐๐ป
TKM That rear main seal is a tough job to change...the real problem is you dont have a source for a quality seal. The originals were asbestos braid that is not available today. Do you have PCV or road draft tube positive crankcase ventilation might solve it. If you change be sure its vented or vacuum can suck the gaskets out of it. Also there is a tool kit to help that seal get in there ! Hope i'm telling you right its been 50 yrs. ! If not right someone will chime in .
ace skiver
Depending on the year of your engine, these rear main seals are probably the best that are readily available. https://bestgasket.com/rear-main-seals/They both have worked for my trucks.
OP
Thanks so much guys, based on your comments and my research, I think Iโll just put up with the drips for now. Engine starts and runs well โ sometimes itโs best to leave well enough alone.
