We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
0 members (),
67
robots. |
Key:
Admin,
Mod
Forums60
Topics127,506
Posts1,032,015
Members45,793
Most Online1,229 Jan 21st, 2020
 *New Garage Heater*
OP
Since I'm retired now and spending a lot more time in the garage I installed a heater today. Had to run a new 220 line which went pretty quick. The instructions said one lag bolt in the middle of the bracket was good if you wanted to swivel the heater. Seemed a little to flimsy to me so I bolted it to the ceiling with three bolts. This is a 5000 watt heater (Comfort Zone) that is suppose to be good for up to 500 sq ft. My garage is 20X25 so the math works out right on the money. It was 36 degree outside so I set it on medium and after an hour it was up to 58 degrees so that's where I set the thermostat. With a light jacket that's all I need. https://photos.google.com/share/AF1...V1l3SWtmYVYzbkQ4c0VyMjFqdHBGdTVRU2NRQkZR
 Re: *New Garage Heater*
Stovebolt Photo Moderator
5000 watts is about 17,000 BTU's Electric is 100 % efficient so nothing goes up the stack. 58 degrees is nice when it's 36 outside. Minimize opening the doors and plug everywhere you may feel a draft and you should be good to go. I dream of the day I retire and can tinker in the garage.
Thanks for your USAF service sir
Joe
I've got one of them in my stock room where I keep my steel. Without it all would turn to rust in the spring when the ceiling sweats for a month. I keep the stock room at 45°all thur the winter. dg
You know you live in Indiana, you should have put in a split system in for the hot humid summer.
OP
I assume split system means heat/AC. In the summer months I like the front and back doors open with fans running. Just don't like being boxed in. I want to hear the birds, the traffic, and the neighbors yelling at each other ☺
My house garage is heated and it also has A/C off the house furnace but my shop has neither.
So what do you do in the Winter Ron, spend all the days in front of the TV watching the soaps???? I tried salamanders in the barn when I first moved in. If I ran that for an hour and it was like working in a rain forest. H2O....a by product of combustion. Then it was the wood burner, got tons of Ash trees everywhere you look, so no shortage of fire wood. Spent half my time in the shop feeding the pig. Finally got the gas lines run out to the barn a couple of years ago and a gas burner hooked up to heat 1/2 the barn. Still supplement the furnace with the wood burner when it's really cold in there. All that has allowed me to put some time in each day all thru the winter months for the last 8 years that I've been out at Shangri La. Denny G Sandwich, IL
Well Denny I knew someone was peeking in but I did not know who. I work on little projects on the truck. Watch the birds on the suet and seed feeder. Read. Make political comments on **** that get deleted, I mean fact-checked. Cook for a lady friend. Of course, checking in here from time to time. And NAP.
OP
Hey....I like the napping part ☺
Hey....I like the napping part ☺ That's turning into my 15 minutes a day that I should be working on the truck.
Kevin Newest Project - 51 Chevy 3100 work truck. Photos [ flickr.com] #2 - '29 Ford pickup restored from the ground up. First car '29 Ford Special Coupe Busting rust since the mid-60's
