Well we are about to get started on some automotive electrical work when the wagon returns from Upholstery, and in an attempt to limit/eliminate any need for butt splices, I was looking around for various automotive "W" crimp terminals that were available. I found a gem of a store,
www.repairconnector.com [
repairconnector.com] that carries much of the old style crimp on terminals, as well as some of the newer stuff. We do have some new light fixtures going in, and to help in eliminating excessive connections (ie: butt splices) I found they carry the replacement terminals for lamp base sockets.. (and terminals for fuse blocks, and.....)
Some of the terminals we just picked up from Repair Connector
[IMG]
https://hosting.photobucket.com/images/y167/rmccartney/IMG_8610.jpg[/IMG]
Typical replacement light housing has pigtails that will require some type of splice...
[IMG]
https://hosting.photobucket.com/images/y167/rmccartney/IMG_8619.JPG[/IMG]
New lamp base terminals from Repair Connector
[IMG]
https://hosting.photobucket.com/images/y167/rmccartney/IMG_8615.JPG[/IMG]
[IMG]
https://hosting.photobucket.com/images/y167/rmccartney/IMG_8616.JPG[/IMG]
These terminals will help us get rid of some splices..
[IMG]
https://hosting.photobucket.com/images/y167/rmccartney/IMG_8617.JPG[/IMG]
If you have a need to repair/replace any of your automotive electrical wiring, give them a look, they may have something you can use..
