The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
18 members (55 SHAKER, 38 Coal Truck, Hotrod Lincoln, 78buckshot, 66flea, 32vsnake, 1 invisible), 150 guests, and 3 robots.
Forums58
Topics122,612
Posts989,237
Members44,498
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1955.2 Chevy 3600 power steering options
#1391109 Sun Jan 03 2021 07:56 PM
I have an original 1955.2 Chevy 3600. I am wanting to add power steering and have not come across a good option for doing it without lots of fabrication. Any suggestions from anyone would be helpful. I am not considering upgrading my engine unless I went all in and added 4x4.
thanks
George
Re: 1955.2 Chevy 3600 power steering options
mcwinery #1391128 Sun Jan 03 2021 09:23 PM
George,
Does your existing box go through the left frame rail to the pitman arm, then forward to a J shaped steering arm attached to the left front wheel with the tie rod behind the axle?
If so, there is a 400 series box recently available that is made to fit that application using everything from drag link forward. Box has a gold irridate plate with many flathead bolts for attaching to truck frame. Look on E-bay.
Other options include moving the box in front of the axle, using the same drag link, might need to adjust length, if the tie rod is in front of the axle with crosswise drag link, get a GM Saginaw box and move the pitman arm to the crosswise position. This last paragraph applies to all trucks, not just GM
This is the CPP unit mentioned below.
Ed
mcwinery #1391132 Sun Jan 03 2021 09:25 PM
Crusty Old Sarge
Classic Performance Products (CPP) has a steering box that mounts in the stock location and uses the factory column. You would still need to add a power steering pump to your engine. https://www.classicperform.com/Store/1960_1972_Chevy_Truck/CPP5559PSK-OC.htm
Craig
Come,Bleed or Blister somethings got to give!!!
59' Apache 31, 327 V8, Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting)
mcwinery #1391210 Mon Jan 04 2021 03:52 AM
I went with EPAS (electric ) P/S. You just cut a chunk out of the original column, place it inline under the dash and run a power wire. It works without the engine running just like my electric A/C. It has adjustable gain. If it fails it just goes back to normal. Really cleans up the engine compartment. No hoses, pumps or pulleys and original steering box. You could install it with a hacksaw drill and file.
Moderated by  KCMongo
