The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (JW51, 62Stick, Hedgehog, 5 Window 9434, 2 invisible), 160 guests, and 3 robots.
Forums58
Topics122,595
Posts989,018
Members44,491
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Engine work in Michigan
#1360721 Sun May 17 2020 04:25 PM
TKM Offline OP
My 49 3600 (216) needs a new rear seal can anyone recommend a good rebuilder/shop that can handle this without me pulling the engine ? Southeast Michigan is preferable. Thanks !!
Re: Engine work in Michigan
TKM #1367090 Tue Jun 30 2020 02:59 AM
Jim Hughes in Belleville,mi.is a good shop to use
He worked on my 54 and did good work
TKM #1370705 Sun Jul 26 2020 01:54 AM
TKM Offline OP
Thanks Keith ! I will definitely check him out ๐Ÿ‘๐Ÿป
TKM #1390735 Fri Jan 01 2021 02:29 AM
TKM That rear main seal is a tough job to change...the real problem is you dont have a source for a quality seal. The originals were asbestos braid that is not available today. Do you have PCV or road draft tube positive crankcase ventilation might solve it. If you change be sure its vented or vacuum can suck the gaskets out of it. Also there is a tool kit to help that seal get in there ! Hope i'm telling you right its been 50 yrs. ! If not right someone will chime in .
TKM #1390745 Fri Jan 01 2021 03:59 AM
Depending on the year of your engine, these rear main seals are probably the best that are readily available.
https://bestgasket.com/rear-main-seals/
They both have worked for my trucks.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
TKM #1392011 Sun Jan 10 2021 12:05 AM
TKM Offline OP
Thanks so much guys, based on your comments and my research, I think Iโ€™ll just put up with the drips for now. Engine starts and runs well โ€” sometimes itโ€™s best to leave well enough alone.
TKM #1397447 Mon Feb 15 2021 07:06 PM
TKM In the olden days some mechanics would take down the rear cap and drive a pin punch about up in the seal on both sides then pack a piece of seal in both sides then put in new bottom half,started to say about a 3/16 punch this was to help tighten it up. This was when you could get asbestos seal . Crude way to do !!
TKM #1399767 Wed Mar 03 2021 12:34 AM
I've tightened an upper rope seal by driving a piece of the stainless steel strip that retains the rubber in a windshield wiper blade between the upper seal and the engine block, and putting a new piece of rope seal in the main cap. It beat fighting with installing the upper seal section while trying to make a living working for 50% of flat rate time in a production shop.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Moderated by  63burban, Randy Baumann
