The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (Wally / Montana, Greg_H, Duwop, 3hansens, crenwelge, 1 invisible), 136 guests, and 4 robots.
Forums60
Topics124,691
Posts1,006,443
Members45,005
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Angle Grinder
#1389123 Sun Dec 20 2020 02:25 PM
I'm in the market for an angle grinder primarily for removing rust. It will be my Christmas present to myself.
I'm thinking a compact design with battery power would be good for working in tight places and for the frame. Any advice on brand, battery power, compact design models, etc. ?
1965 Chevy C10 Longbed Fleetside
(Engine needed, originally 230)
Re: Angle Grinder
WarEagle1 #1389126 Sun Dec 20 2020 03:07 PM
If you do that, buy lots of batteries and an extra charger. My 4 inch Makita angle grinder plugs into the wall, and the battery never runs down.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Angle Grinder
WarEagle1 #1389140 Sun Dec 20 2020 04:14 PM
Workshop Owner
The ones I like have a paddle switch. Way easier to use. I've had good luck with Dewalt, Makita and Bosch rechargeable power tools.
J Lucas
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
1959 Chevy Apache 31 Fleetside
1959 Chevy Apache 32 Fleetside
1959 Chevy Viking 40
My Flicker Photos! [flickr.com]
Re: Angle Grinder
WarEagle1 #1389160 Sun Dec 20 2020 06:41 PM
I have a Milwaukee M18 FUEL 2780-20 Cordless Brushless Grinder 4 1/2 5" 18 Volt. I love it. It runs a long time. Gets in hard to reach spots. I also have the
Milwaukee M18 2663-20 Cordless 1/2" High Torque Impact Wrench 18 Volt. Not Cheap but worth the investment! Again, the Batteries last a Long Time. (Same batteries ONE charger!)
Good Luck & Merry Christmas.
Todd
Re: Angle Grinder
WarEagle1 #1389165 Sun Dec 20 2020 07:24 PM
Just remember with a battery it might be a little bigger and heavier and you will have to charge it and may need extra batteries .With a cord grinder good for if you need it in a power outage or out in a scrapyard or field .
kevinski 1954 GMC 9300 Welcome to the virtual Garage [stovebolt.com]
Re: Angle Grinder
WarEagle1 #1389166 Sun Dec 20 2020 07:30 PM
I like my makita corded
When I was cleaning up my frame I got a HF CHEAPO and kept a cup wire wheel on that. Had a flap disc on the makita
Was worth it for time saving
If I get a battery operated one i’lll just get the same brand as my drill , bosch
Re: Angle Grinder
WarEagle1 #1389169 Sun Dec 20 2020 07:39 PM
I bought two HF units, the $10 one which has a slide switch that is a PITA to use, and it wore out the shaft bushing when I put a cup brush on it. The other was the $20 paddle switch unit that has been my go-to for my restoration work. It's still running strong since I bought it at least 4 years ago. When the really cheapo one went bad, I bought a spare paddle switch unit for backup. It hasn't seen any service yet, and I'm on the downhill side of needing it for my truck work. All of them are corded. My experience with battery powered drills/impact drivers is that when you need to use it, the battery needs charging, delaying the work.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Re: Angle Grinder
WarEagle1 #1389175 Sun Dec 20 2020 08:03 PM
We use 125 mm Milwaukee fuel grinders to cut rebar and give them a pounding very reliable I would say bulletproof but have used HRL s gun and see what damage they do battery technology is a lot better now
Re: Angle Grinder
WarEagle1 #1389211 Sun Dec 20 2020 11:50 PM
7
My best grinder is a Makita 7", I bought it new almost 40 years ago and it has never let me down, zero failures and zero maintenance.
1957 Chevrolet 5700 LCF 283 SM420 single speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto
Re: Angle Grinder
WarEagle1 #1389226 Mon Dec 21 2020 01:46 AM
I too have a 40yo 7" Makita. Takes both hands to carry it around but made to take a beating. The type of work you are planning is 1)crappy, so you want it to go as fast as possible and 2)Very hard on the grinder.
I have several air grinders, the big 7", several 4.5" grinders and a cordless Dewalt. The cordless is good for quick (15min) jobs away from a 120v plug. The air grinders are more for medium load, non-stop, hours of continuous running (they are light and generate no heat themselves), the 4.5" are good for heavy metal or paint removal in a small area and the big 7" is likely my first choice for much of what you are describing.
You don't want to skimp here.
Page 1 of 2 1 2
Moderated by  48bigtrucks, MNSmith
