The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (Justhorsenround, Charles in CA, Joe H, 3 invisible), 131 guests, and 7 robots.
Forums60
Topics123,918
Posts1,000,036
Members44,782
Most Online1,229
Jan 21st, 2020
Image Posting Policy
8an or 10an for 261 full flow oil filter
#1388187 Sun Dec 13 2020 09:25 PM
Hi all! I'm getting ready to plumb my remote filter. I can use 8an or 10an. Is the restriction difference enough to worry about? I have the fittings for 8an tubing, but am wondering if I should get new fittings and use 10an. Thoughts?
My Webshot Photos [community.webshots.com]
62 Fleetside 4spd 235 w/O.D. posi 3:90
90 Subaru Legacy Wagon AWD 2.2 5sp
13 Ram Tradesman C/V
http://www.stovebolt.com/gallery/madia_matt_1962.html
Re: 8an or 10an for 261 full flow oil filter
bigmacdaddy #1388188 Sun Dec 13 2020 09:31 PM
AN fittings are measured in 1/16" increments, so a #8 line is the equivalent of 1/2". That should be plenty of volume to support a full flow system. All a #10 line will do is contain a few ounces more oil, with no real advantage at the pressure and flow rate of the 261 oil system. Be sure the dowel pin in the flow control system is in the "in" position, as that's the only way a 261 will function as a full flow oil circuit.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
bigmacdaddy #1388260 Mon Dec 14 2020 01:51 PM
Can someone show a picture of where that dowel pin is 0n a 261 engine. I forget.
1951 Chevy 3100 5-window
261 cu in, 348 Head, Split Fenton Exhaust
Offy with Dual Weber 2 Bbl Carbs
bigmacdaddy #1388262 Mon Dec 14 2020 02:13 PM
'51Bowtie, to your question, here is a 261 block, driver's side view, showing the dowel pin pushed in for full flow filtering (green arrow). In this configuration, the two NPT threaded ports (blue arrows) must be connected either through a full flow filter or at least with a length of pipe or hose, 1/2" ID, in order for oil to reach the oil galleries and bearings.
Doug
bigmacdaddy #1388429 Tue Dec 15 2020 06:04 AM
Thanks Jerry! 8an it is!
drdoug #1388455 Tue Dec 15 2020 02:40 PM
[quote=drdoug]'51Bowtie, to your question, here is a 261 block, driver's side view, showing the dowel pin pushed in for full flow filtering (green arrow). In this configuration, the two NPT threaded ports (blue arrows) must be connected either through a full flow filter or at least with a length of pipe or hose, 1/2" ID, in order for oil to reach the oil galleries and bearings.
Yep, now I remember. Thanks Doug.
Moderated by  Woogeroo
