WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
2 members (hvstove, 51 3804),
267
robots. |
Key:
Admin,
Mod
Forums58
Topics121,943
Posts983,260
Members44,348
Most Online1,229 Jan 21st, 2020
 Re: Replacing Rivets for bolts
Boltergeist
The term "Plastic" covers a wide variety of synthetic materials with different physical properties- - - - -Nylon, Teflon, Rayon, Dacron, etc.- - - -and those are just the petroleum-based products produced by DuPont. There's a story about how those names came to be. One of the very early "computers" back in the 1940's was tasked by DuPont with combining random syllables to suggest names for new products, resulting in the above names for the various products their chemists were churning out. One such name was rejected, after a researcher from another country pointed out that in his language, the word meant "outhouse"! That story was shared with me by a DuPont chemical engineer who also ran one of the race cars my father built engines for. Jerry
The murder victim was drowned in a bathtub full of Rice Krispies and milk. The coroner blamed the crime on a cereal killer! Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
Boltergeist
The simple, effective, and more or less foolproof way to install shock absorber mounts, crossmembers, and other parts that carry suspension loads are "Huck" bolts. They're basically pop rivets on steroids and they clamp pieces together tightly and expand to fill holes completely, preventing any relative motion between parts. They're a lot simpler to install than hot rivets, and they have a 50+ year history of holding big rigs together. Some types of them can be installed without special tools- - - -nothing but an impact wrench is needed. Jerry
Jerry, I think you are confusing Huck bolts with structural blind rivets. The largest Huck bolt or magna grip that can be pulled with air over hydraulic is a 3/8". The Huck 256 which pulls them costs around $3,000 without the pulling tip. The nose piece is around $500. I own two of them. I keep a 3/8 tip in one of them and a 5/8 tip because we do a lot of trailer repairs. The things that resemble pop rivets are usually called blind Huck or Monobolts. They are in places where it is impossible to use a buck rivet or Huck bolt. Truck manufactures use 5/8 and 3/4 inch Huck bolts. The machine to pull them costs them costs around $100,000. I'm not sure just what you would do with am impact wrench to pull either a Huck Bolt or a blind. Huck bolts are cheaper to install at the factory, but they break after a lot of salt exposure. I replace them with grade 8 flange bolts. I think this whole thread is going nowhere and probably should be deleted.
I don't think the thread should be deleted. It is getting a bit off track, but some good discussion and info here. It's got me looking up some of the products mentioned.
Kevin First car '29 Ford Special Coupe #2 - '29 Ford pickup restored from the ground up. Newest Project - 51 Chevy 3100 work truck. Photos [ flickr.com] Busting rust since the mid-60's
OP
@crenwelge I looked at the flange bolts. It looks like it has a round head, how do you keep it from spinning when tightening it. Thank you all for all the great information and options.
Mark
I used flange bolts when I shortened the frame on my 630. Does away with washers, too.
Ed
