Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time. Look to see what's been cancelled or postponed.
Needing the threaded adapter that attaches the compression fittings from oil pump tube to pipe thread on a 1954 261. This is for the oil tube from oil pump to the block. Not sure if same for pressure oil 235. Posted pictures below. Anyone have this from a stripped down but unusable engine? Thank you. Tom
Tom, I guess I can say I feel your pain as my machinist engine threw away my old oil pump (with that fitting attached) since the kit came with a new oil pump. So I was in the exact position you are in. I searched anywhere and everywhere for it and no luck. It is an odd or "bastard" fitting. The only place it was ever used is in a 235/261 Chevrolet straight six to my knowledge. Sorry I don't have one and maybe a stovebolter will have one as the only place you will find one is in a old block.
Thanks. I am not familiar enough with thread sizes, but I did check Grainger and they had the 24 thread reducer nipple - on both ends, but not small pipe thread on one side and larger diameter fine thread on the other end. I will check again. May not be seeing it correctly. tom
That's a compression fitting for a 1/4" pipe to a 7/16" OD tube. I'll be using a different size tube from the oil pump to the block on a couple of engines I'm building, so PM me if you don't find one. Jerry
The murder victim was drowned in a bathtub full of Rice Krispies and milk. The coroner blamed the crime on a cereal killer!
Yes - that fitting is an odd duck. I must be getting old because for the life of me I am careful about keeping parts. But this one somehow wandered off and became lost. wondering how I could have lost it... both my mind and the fitting. This is the second time this week that I have found myself wondering this. It must be Old Geezers disease.
