The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (OldCarKook, John Dlugos, TPR57C, Hambone, 3800GUY, 1 invisible), 179 guests, and 3 robots.
Forums50
Topics122,208
Posts980,386
Members44,177
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 3 of 3 1 2 3
Re: 1956 AC oil filter canister color?
53moneypit #426891 Thu Jun 26 2008 05:34 PM
ace skiver
Dave,
Did that person indicate what were the words done in ivory lettering on factory installed filters?
Tim
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
tclederman #426911 Thu Jun 26 2008 06:37 PM
The Fram was orange with a black lid, and the filter cartridge was orange.
Stovebolt thread
Ebay link
Courtesy of Wada - who started this topic.
David Colter
pics * 1954 wrecker * 1948 Chevy 1-Ton
54TOW #426947 Thu Jun 26 2008 08:13 PM
No but it would be the available decal that everyone sells I'm certain. LMC has both AC and Fram decals for AD and TF series trucks.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #426952 Thu Jun 26 2008 08:38 PM
ace skiver
Dave,
I'm not so certain that an ivory/white decal is available for the lid. The closest decal that LMC has for the top of the lid is the 38-0088 filter that everyone has for 55-62 AC canister filters (the lettering is not white/ivory, it's Chevy Blue lettering). Any leads on a white lettering decal to go around the rim of the lid would be appreciated.
Denny,
Your source might be right about the ivory lettering for around the top of the lid - I can still see some light colored lettering around the top (but I cannot read what it said).
Tim
Tim
tclederman #427496 Sat Jun 28 2008 11:35 AM
I think that was exactly what I quoted a few replies earlier Dave, thanks for reinforcing it. How ever, I believe the brackets were the same. The only difference that I have seen is that the inlet location is in the front on the later ones and they were clamped to the back of the intake to clear the snout on the later air cleaners. If you have any documentation on the brackets being different I’d appreciate seeing it.
Tim, No I was quoting a reply that I got from Gene Schneider (Chevgene) on that, he is as you know, probably on of the more reliable sources when it comes to vintage Chevy's. That said, I would question the filter covers with the wide flange being avalable into the late 50's, which I had mentioned before.
I have a couple of those round decals from the vendors on the shelf and the lettering is blue. I don't know if any one reproduces the white ones. The only one with white lettering that the vendors sell is a rectangular decal which they claim is for '58-67 6 & V8. That doesn't ring a bell with me.
Denny Graham
Sandwich, IL
54TOW #1385980 Thu Nov 26 2020 04:41 AM
I found a cannister that had original rust and paint on it along with a drain port in the bottom. It was cheap to buy, I thought it would be great to have the drain port in the bottom to make oil changes a little more clean. I plan to clean it up and swap it out with the one on my truck. The rust was pretty bad. During blasting process, the body revealed its true orange color for a brief instant in some locations. The lid had what appeared to be the Fram decal outline still in place. I'm going to use self-etching primer and paint the cannister Chevrolet engine gloss orange and paint the lid gloss black. I painted the one on my truck gray with a black lid, not knowing what it really should be! I took a picture of another cannister filter on a '56 at a show. I thought it looked good. Here is the example. I have a decal set that I bought that has the FRAM gold lettering, like the one in the picture.
1958 Chevrolet 3600 NAPCO 4x4 Apache
"Calvin"
More pictures on Photobucket
Wada #1386054 Thu Nov 26 2020 06:54 PM
Wada #1386091 Thu Nov 26 2020 11:38 PM
That filckr albums one of my favorites.
Wada #1388143 Sun Dec 13 2020 03:24 PM
After some searching and debate, I'm going to paint the lid chevy orange and the cannister chevy blue. I found that I have both of the decals in my assortment of restoration supplies. I have been using the Fram C21 filter for changes, i'm sure that both are the same size and application use. The AC Delco decal has a note on it being used for 55-61 applications. Its not as cool looking as the FRAM decal.
"Calvin"
Wada #1388492 Tue Dec 15 2020 05:25 PM
Curmudgeon
The picture is not mine.
It's not GM blue, or F#$d blue nor D*d&@ blue but AC Delco Logo blue.
Maybe take it to a local paint store and see if they can do a color match.
Page 3 of 3 1 2 3
Moderated by  Woogeroo
