The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (Flatblu4748, 3B, Joe H, drdoug, Brian Wise, 2 invisible), 176 guests, and 3 robots.
Forums50
Topics122,195
Posts980,260
Members44,173
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Help or suggestions
#1385443 Sun Nov 22 2020 03:05 AM
homer52 Offline OP
I am cleaning up the many grill clips for my 41 Plymouth, I am guessing they are some form of spring steel. I put them in a small can that I perforated and put them in my bed blaster and shook as I held the nozzle in the can. It worked perfect but I now have bear metal clips. Thes4 clips are quite small and have very tight tolerances so I'm thinking that painting is out of the question. Any thought on a very thin coating to hopefully dip them in? Maybe something like pickling? I hate to put them in bare metal, they were quite rusty when removed, it was just surface, no pitting them. Any thoughts? Dave
Pictures [s300.photobucket.com]
41 Chevy
41 GMC resting peacefully
46/7 Chevy
45 GMC panel truck in line for restoration
41 Plymouth in the restoration process
41 Chevy coe in line for restoration
Re: Help or suggestions
homer52 #1385448 Sun Nov 22 2020 03:39 AM
Dave, I'm getting ready to zinc plate some stuff. The materials are on the way.
Here's a link to a guy who did this who's method I'm going to use. DIY zinc electroplating [southsandia.com]
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
homer52 #1385456 Sun Nov 22 2020 05:40 AM
homer52 Offline OP
Let me know how it goes. Dave
41 Chevy
46/7 Chevy
homer52 #1385457 Sun Nov 22 2020 05:47 AM
homer52 Offline OP
By the way I got the decals, very nice! Thankyou. Dave
41 Chevy
46/7 Chevy
homer52 #1385461 Sun Nov 22 2020 06:44 AM
Will do. It will probably be a couple weeks before I get everything set up.
You're very welcome.
homer52 #1385465 Sun Nov 22 2020 08:42 AM
Homer52,You might post here your question. [facebook.com]. They might give you grief about being a member if you are not. Not much they can do about it. BTW I am a member.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery
2017 Buick Encore
Pix on Photobucket
homer52 #1385830 Wed Nov 25 2020 10:57 AM
Unrepentant VW Lover
Check out Eastwood's products. I've used their metal blackening/black oxide system [eastwood.com] and thought it was pretty good.
"Paul! Klaatu barada nikto. KLAATU BARADA NIKTO!!!!"
'49 Chevrolet 3804
homer52 #1385862 Wed Nov 25 2020 03:57 PM
Workshop Owner
I second the black oxide.
J Lucas
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
1959 Chevy Apache 31 Fleetside
1959 Chevy Apache 32 Fleetside
1959 Chevy Viking 40
My Flicker Photos! [flickr.com]
homer52 #1385904 Wed Nov 25 2020 08:44 PM
I just checked out that stuff and it looks like it's basically an epoxy type (2-component) paint system. The problem I see with using that is being able to completely coat things like wire clips. There's likely going to be a void where you'd need to hang them for spraying. Pretty fiddly to get complete coverage.
Once the rest of my stuff comes for zinc electroplating, I'll report on the results.
homer52 #1385910 Wed Nov 25 2020 09:51 PM
You can also plate with nickel with common household stuff...aside from pure nickel of course. You'll need to buy that, but it isn't expensive at all. Nickel plating will look like stainless steel, chrome or sometimes black...depending on what you're plating and how it goes for you. Sometimes I find a layer of copper first helps things (which is also very easy to do). And when you're finished it won't rust and you certainly won't spend as much as you'll spend on some of the mail-order kits. See if this helps you decide: https://www.instructables.com/High-Quality-and-safe-Nickel-Plating/
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Page 1 of 2 1 2
Moderated by  Bouncer, Justhorsenround, Tiny
