The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (KEVINSKI, Bill Trotter, HFfarms, 3 invisible), 242 guests, and 3 robots.
Forums50
Topics121,501
Posts974,059
Members43,945
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Help with floor mat stud locations
#1385402 Sat Nov 21 2020 11:12 PM
Could someone please help me out with dimensions to the studs that hold the floor mat in an AD truck?
I had to replace parts of the kick panel and have one clinging to a piece of rusty metal that I need to reinstall. I think it goes on the right side near one of the inner fender bolts, but don't have those holes currently either (dimensions to those would also be awesome). Not sure if there was also a stud on the left side near the parking brake bracket (maybe that's what the hole was for ohwell), or if I need to track down another stud so I can put them on both sides.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Re: Help with floor mat stud locations
klhansen #1385409 Sun Nov 22 2020 12:13 AM
Do you still have your old floormat? The studs line up with the holes to keep the mat from sliding up under your feet. I would lay out the mat and trace the holes where they go.
klhansen #1385416 Sun Nov 22 2020 12:41 AM
I think those pins are for original firewall pad
Floor mat on drivers side held up by other means
Check your FAM
klhansen #1385428 Sun Nov 22 2020 01:29 AM
You sent me through old pictures of the teardown of my 54. Cab not available to look at right now but I can't find pictures showing anything above the toe-board on mine so I have to stick with floor mat pins. You said AD but did not specify year so I probably have not helped at all.
klhansen #1385429 Sun Nov 22 2020 01:37 AM
I only have old pic of drivers side
No help for you
DADS50 #1385438 Sun Nov 22 2020 02:29 AM
That's funny. I didn't even have a FLOOR when I got my truck. grin
No, I recall pulling the firewall pad off. It was held on by wire spring clips.
Your first pic helps a lot. It tells me that pin with a bit of floor attached goes on the driver's side. Once I drill for the parking brake bracket, I can position that pin. Thanks. The FAM shows the pins, but not the locations.
Now I just need to see if someone can get me the location of the passenger side pin (FAM shows one there) and the location of the inner fender bolt holes.
Stovebolt comes thru again. thumbs_up
klhansen #1385440 Sun Nov 22 2020 02:42 AM
Maybe originally there was an eye for the jute?
I have a couple old bad pics of passenger side. Something close to upper bead
klhansen #1385447 Sun Nov 22 2020 03:33 AM
Yep, that's the one that's shown on the FAM. If someone could measure from the kick panel to the stud, that would get me where I need to be.
klhansen #1385452 Sun Nov 22 2020 04:15 AM
Here is a shot of my truck during teardown. I don't know if it will give a point of reference or not. Cab is not readily accessible or I would get measurement for you. Hope this helps. I still stand my ground that the posts hold the upper part of the floor mat though.
klhansen #1385460 Sun Nov 22 2020 05:54 AM
Thanks Greg
I agree that they're for the floor mat. That pic helps.
Page 1 of 2 1 2
Moderated by  HandyAndy, klhansen
