The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (KEVINSKI, Bill Trotter, HFfarms, 3 invisible), 242 guests, and 3 robots.
Forums50
Topics121,501
Posts974,059
Members43,945
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Joint to identify. Chevy 1-1/2 ton truck
#1385101 Wed Nov 18 2020 07:35 PM
GB69 Offline OP
Hello, Everyone. Could someone help me identify these U yokes to repair (front axle drive?). Also if it is possible to repair or replace them. The tube yoke that is cut is approximately 9" long.
They would have been parts from a Chevy G506 or maybe from another Chevy/GMC truck.
Regards
Chevy 4x4 G506
Re: Joint to identify. Chevy 1-1/2 ton truck
GB69 #1385258 Fri Nov 20 2020 01:58 AM
Almost looks like a PTO drive. Any driveline shop can rebuild that for you. Whether you do the u-joint work yourself, or have them do the whole thing.
GB69 #1385265 Fri Nov 20 2020 03:02 AM
GB69 Offline OP
Thanks for the reply. I think it may be related to the PTO. This truck had been a fire engine and they had PTO for auxiliary equipment such as the front water pump and the hoses. I think that this shaft could have been for one of those pieces, perhaps the same type as those used in the front winches.
Chevy 4x4 G506
GB69 #1385267 Fri Nov 20 2020 03:16 AM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
As Mark said, find a Driveline shop near you and take it to them. They will build you a new one. You may just be surprised at how inexpensive it can be. My complete driveshaft for the ā€˜62 C-10 restomod was right at $250 including ujoints.
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iā€™m #2)
ā€˜39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
GB69 #1385281 Fri Nov 20 2020 01:37 PM
It is definitely not a G506 front differential driveshaft. The front and rear driveshafts on the G506 are identical. Looks more like a PTO driveshaft to me, but not one that I can identify.
GB69 #1385430 Sun Nov 22 2020 01:37 AM
GB69 Offline OP
Could it be an adaptation of a part from another vehicle? It appears to have the appearance of an agriculture Cardan-type shaft. This shaft was in the front, attached with a rope to the radiator. That's why I thought it had to do with the water pump. But I know someone who has a fire engine G506 with a front mounted Darley pump, and it isn't the same as this one.
Thank you for all of the comments. It is very helpful.
Chevy 4x4 G506
GB69 #1385673 Tue Nov 24 2020 01:52 AM
When you stated
"was in the front, attached with a rope to the radiator" reminded me of the engine driven hydraulic pump used by @Heil Equipment to supply the hydraulic system on refuse trucks. PIA to replace engine belts.
I looked and looked but discovered it was unobtaiium!
Moderated by  ndkid275, Rusty Rod
