The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (billypylot, D B Cooper, archburycontrol, 3B, fonz8261, 1 invisible), 303 guests, and 3 robots.
Forums50
Topics121,501
Posts974,061
Members43,945
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1954 1 Ton Center Bearing
#1385324 Fri Nov 20 2020 11:08 PM
TrevorC Offline OP
I am in the process of finally starting this rebuild project after 6 years on hold. I am knocking out the U joints and need to pull the center bearing but am having issues with how it separates from the drive shaft. I am guessing the metal retainer on the shaft at the base of the splines has to come off??? Or does the whole carrier assembly slide off the end of the shaft??
Any help would be appreciated so I don't inadvertantly damage something.
Cheers
1954 GMC 1400-9430
Re: 1954 1 Ton Center Bearing
TrevorC #1385405 Sat Nov 21 2020 11:42 PM
7
The bearing is pressed on to the shaft, the silver cup is just a slinger, won't do much good to remove it, you'll still have to press the bearing off.
1957 Chevrolet 5700 LCF 283 SM420 single speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto
TrevorC #1385495 Sun Nov 22 2020 06:42 PM
Here's a couple of illustrations that may help. I replaced the entire carrier bearing assembly on my 1954 3604. If you have a Shop Manual, it helps.
Ronnie
1954 Chevy 3604 - A work in progress...
" You can't keep dancing with the Devil and wonder why you're still in hell"
Moderated by  Grigg
