The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 members (GMCJammer51, 68ironhead, Hotrod Lincoln, Gazz, Huck, 3 invisible), 239 guests, and 3 robots.
Forums50
Topics122,185
Posts980,148
Members44,168
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Changing to correct side mirror for 1954 3604
#1385070 Wed Nov 18 2020 03:28 PM
Dusty53 Offline OP
Once upon a time a previous owner installed some big truck mirrors. Holes in the door and top of the door above window have been welded shut and doors refinished. I plan to buy and install the correct mirror. I recall , or think I do, that someone posted the "template" that is used to locate the holes for the mirror on the cowl. I looked inside under the dash and it does not look like the "optional" mirror was ever installed. Was there a "backing plate" for that mirror that went on the inside? Advice, suggestions, anyone ?
Ronnie
1954 Chevy 3604 - A work in progress...
" You can't keep dancing with the Devil and wonder why you're still in hell"
Re: Changing to correct side mirror for 1954 3604
Dusty53 #1385073 Wed Nov 18 2020 03:42 PM
There is a template/instruction set that came with the big truck mirror kit. You just flip it for the opposite side. There is a plate underneath for the bolts to go through under the cowl on both sides.
https://www.flickr.com/photos/advance-design_parts_co/9647482921/in/album-72157631868452754/
If you PM me with your email I can send PDFs of the template and instructions. It works for locating the small truck mirrors as well.
Dusty53 #1385074 Wed Nov 18 2020 03:58 PM
AD Addict
Look closer. There is a support that already has the proper holes punched out that you can use as a locater to drill out the outer sheet metal. You will drill it it out from the inside. You may have to remove glove box to get access to them.
I borrowed the picture from LonnieC from a previous post. [Link]
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Brad Allen #1385080 Wed Nov 18 2020 05:24 PM
Dusty53 Offline OP
PM sent, thank you!
Ronnie
Phak1 #1385081 Wed Nov 18 2020 05:28 PM
Dusty53 Offline OP
Let me get back in there with a mirror on the drivers side and see if I can see those. Thanks Phil! Between you and Brad I'm bound to get it right.
Ronnie
Dusty53 #1385093 Wed Nov 18 2020 06:43 PM
Full post with pics and links
I used a spring loaded center punch from the inside once I located the position. It left a small dimple on outside the I punched and drilled.
Will be hard to do if your truck is “together”
But your going to have to get in there to hold a wrench anyway
https://www.stovebolt.com/ubbthread...5583/re-left-side-mirror.html#Post955583
Moderated by  HandyAndy, klhansen
