EVENTS
Check in for status!
Jump over to the
Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Forums50
Topics122,129
Posts979,674
Members44,158
Most Online1,229 Jan 21st, 2020
 Re: Speedometer drive gears
I have one of the aforementioned speedometer ratio adapters but I have no idea what ratios it changes. It is made by Stewart-Warner with the following numbers: 668F S12 1 2020 X. If anyone knows how to decode these numbers it may be usable to somebody. I have no use for it so if someone is interested you can PM me. Fred
Unconventional Thinker
Way back when, I swapped in a Dana 60 with 3.54 gears, and the truck came with 4.57 gears. The speedometer read 65 but I was doing at 80. I used the tachometer to know what the speeds were, and created a chart for when I tried a different tire size, so I knew what the new rpms were reading at specific speeds. I also didn't know about speedometer adapters back then, so there is that...lol...
Shane
Shane's Toys... 2007 Forester XT Limited (2nd Owner) 1991 Cherokee Laredo (2nd Owner) 1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner) 1965 Chevy 3/4 Ton Fleetside (3rd Owner)
I have one of the aforementioned speedometer ratio adapters but I have no idea what ratios it changes. It is made by Stewart-Warner with the following numbers: 668F S12 1 2020 X. If anyone knows how to decode these numbers it may be usable to somebody. I have no use for it so if someone is interested you can PM me. Fred Look for a decimal point. Have 2 in front of me, .7333 (1 : 0.733) & 1.2020 (1 :1.20). I've us a GPS speedo app on my phone. Drive 50 mph by digital speedo app, indicated speedometer reading above or below GPS X 2 = % needed read correct.
BC 1960 Chevy C10 driver 235 T5 3.73 dana 44 1949 GMC 250 project in waiting 1960 C60 pasture art G.M dealer tech since 1980 & counting
I can recommend Bobs speedometer shop, I took a speedo and tach from my Vette to him, he fixed me up while I waited.
1957 Chevrolet 5700 LCF 283 SM420 single speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto
Thanks BC, there is no decimal point but it's old. The 1: 1.20 is logical for the one I have. Fred
