The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Time to gathering together!
Fall Happenings
That time of year with some last chances to get together in bunches. Time to check out:
THE SIDE LOT
From Coast to Coast and some International gatherings listed, too.
Next up: the ODSS gathers this week (Sept 22-24) at a yearly ATHS show in Winchester VA.
Since we put up this promo last week, a bunch of new postings of Swap Meets, Cruisin's, and more
in the SIDE LOT.
See what's happening with a Stovebolt Collective near you
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (32vsnake, baldeagle, Peggy M, oldbolter, Lightholder's Dad), 103 guests, and 3 robots.
Forums60
Topics129,095
Posts1,046,668
Members46,190
Most Online1,229
Jan 21st, 2020
Page 2 of 2 1 2
This thread discusses using a Powerglide's 235 engine with a manual transmission - the bushing number is given.
However, there is no conclusion on the fit of that bushing?
Here is another thread about that bushing.
It would be nice to hear from someone who has done this?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Slightly off-topic, but the V8's that came originally with Powerglide transmissions also have the oddball counterbore. Of course, if either engine has ever had a "crankshaft kit" installed, all bets are off! There's no telling which core crankshaft was used for regrinding.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
The 57 motor is a good one to have. Hydraulic lifters, neoprene rear main seal, 848 head, uses precision bearings so no shims required or needed like the 55 and earlier motors. The timing cover will not have the two holes unless someone has already swapped in a timing plate that does, or drilled them. 55 was the last year for two different 235 motors (One for stick motors and one for automatic motors). All 57 cars got the same 6 motor regardless of what trans came behind it so yep, you can install a pilot bushing in the crank no problem. Just use a good one, preferably one made of oilite or similar material. The cheap bushings are not bronze, and some of the bronze bushings are not oilite type impregnated bushings so snoop around and pay a few extra dollars and get a good version. Also, don't grease the id of the bushing. It seals the bronze and the pores and prevents the oil from weeping out and lubing the tip of the transmission input shaft.
Mike
fred c Offline OP
46 Chevy 1/2 Ton 1929 Model A Phaeton
thanks you all very much. I'm cutting and paste all this info into one document so I don't loose it.
Page 2 of 2 1 2
