The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (Ga92009, tom moore, klhansen), 184 guests, and 3 robots.
Forums50
Topics121,404
Posts973,278
Members43,924
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 3 of 3 1 2 3
Re: 1950 Chevy PU Torque Tube Disconnect
MikeA777 #1382160 Sun Oct 25 2020 05:25 PM
My two challenges are
1) find a U joint
2) find the back piece of transmission casing matching what Pre '68 Dave has shown in his picture above. Otherwise I have to pull the engine or rear end to work on the clutch/tranny.
MikeA777 #1382164 Sun Oct 25 2020 05:44 PM
Mike, does your transmission have a reverse lockout lever on the shifter?
My Blog
MikeA777 #1382168 Sun Oct 25 2020 07:39 PM
Dave, the shifter has no reverse lockout lever. It's a straight stick coming out of the top.
MikeA777 #1382189 Sun Oct 25 2020 09:57 PM
My best guess is someone put a 1948 to 1953 3/4 ton 4 speed tranny in your truck.
The reason I say that is because the rear yoke is shorter, which is used in the 3/4 ton partial torque tube/open driveline. 2nd photo
The 1st attached photo is the type of u-joint you need.
Note the longer rear yoke.
The front yoke is hard to find.
MikeA777 #1382344 Mon Oct 26 2020 11:40 PM
Jorb, looks like you're right on a few points. I need a different u-joint assembly and the part in your illustration is nowhere to be found at the moment. If someone comes across this assembly, I would love to know about it. The transmission casing Dave shows earlier in the post would also be most welcome.
Refusing to send the truck to the junk yard, I'm going to try to get an alternate u-joint to work. Hope I don't need to work on the clutch before I find a solution.
A million thanks to all who responded. I'm an absolute newbie, desperate to put this beautiful old truck back on the road.
MikeA777 #1382346 Mon Oct 26 2020 11:42 PM
Did the truck run when you bought it?
MikeA777 #1382347 Mon Oct 26 2020 11:44 PM
DAD, Truck did not run. I have a replacement 235 I'm putting in it
MikeA777 #1382348 Mon Oct 26 2020 11:47 PM
Welding holes, stripping rust, ordering tons of parts, getting nervous.
MikeA777 #1382357 Tue Oct 27 2020 12:51 AM
I don’t believe there was a extension housing with the cutouts made for the SM420 transmission which you have.
My Blog
MikeA777 #1382439 Tue Oct 27 2020 04:54 PM
Looks good,
It would of been nice to know if that driveline was operable, so you could have an idea what needs to be replaced
Looking at the pic of your yoke it looks that there is a keeper on top?
Page 3 of 3 1 2 3
Moderated by  SWEET
