The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (Wayne67vert, papas52, Joe H, DaveV, 47 BOMBER, 1 invisible), 124 guests, and 10 robots.
Forums60
Topics123,918
Posts1,000,033
Members44,782
Most Online1,229
Jan 21st, 2020
Image Posting Policy
aftermarket wiper switch not working after rewiring
#1381166 Sat Oct 17 2020 02:33 PM
Moderated
I have a 1949 3/4 ton Chevy Step Van. I just rewired the whole electrical system, with an updated 12+ hot, 12- ground, spade fuse box. That light up when in use. Everything seems working except heater and wiper switch. The heater has a drop down resistor. Which I have no clue how to wire it. The wiper motor (3 wire, hi, low, & park) works when I connect directly to the battery, without the switch. I bought a new 2 speed wiper switch, thinking the old one was bad. I converted the old switch (B= battery?, A= high?, P= park?, & F= fast or low? letters on back of switch) from bullet connect to male spade connector. New switch has H= high, L= low, P= park & B= Battery letters on the back. I attached pictures. [img]https://www.stovebolt.com/ubbthread...umber/23624/filename/20191021_130225.jpg[/img]
Re: aftermarket wiper switch not working after rewiring
loekey53 #1381575 Tue Oct 20 2020 10:07 PM
I can't tell from your drop-down resistor how it was made. Often you will have 12v hot leading in and two 6v hot connections coming out (one for lower current needs...like the radio and one for higher current needs...like the heater motor). My guess is the terminal to the left is 12v+ and each of the two terminals to the right are 6v+, but without seeing it I could only guess which would be higher amp and which would be lower amp.
On your windshield wipers, are you sure you're getting power to the switch? This should be pretty simple if the switch has power. You're comfortable with how the park circuit works, yes?
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
loekey53 #1381627 Wed Oct 21 2020 04:59 AM
Moderated
I'm certain power is getting to the switch. The drop down resistor I think the terminal on right of the picture is 12v and the 2 terminal on the left are 6v. I'm not sure how to wire it up and to where. If I really need it. Don't understand if it's important. Can't find any information about the use of it. The wiper switch picture the top terminal is P. The 2 in the middle the left is A the right is B. The bottom is F. Not sure how to wire. Tried a new wiper switch wired hot to B (Battery) terminal and put 1 Yellow wire from wiper motor to H (High) terminal 1 Green wire to L (Low) terminal 1 Black to P (Park) terminal and it doesn't work. When I wire the wiper motor wires to the battery, the Yellow wire is High side. When I put both Green and Yellow wire together to the battery the wiper motor goes to low speed. The Black wire sparks but don't notice any other affect. So I'm assuming Black wire is Park. Wiper switch and 2 speed heater are the only items that aren't working for me after rewire.
Moderated by  Rusty Rod
