The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (ASU, 5 Window 9434, 1 invisible), 135 guests, and 1 robot.
Forums50
Topics120,985
Posts969,895
Members43,811
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Seat Belt Question for Lugnutz
#1381241 Sun Oct 18 2020 01:50 AM
Sir:
I found your excellent instructions for seat belt mounting. I have ordered the belts with the threaded mounting plate per your suggestion, which is the subject of my 2-part question: Do I need to use a lock washer or Loctite with the mounting plate, and, will I have trouble with the mounting plate turning when I try to tighten?
Thank you
Re: Seat Belt Question for Lugnutz
WarEagle1 #1381289 Sun Oct 18 2020 08:15 PM
Just saw this. If you are talking about the shoulder belt anchor on the upper inside of the cab, then yes, medium loctite is a good idea. See picture below.
Some I’ve talked to have somehow secured a wrench on the nut that’s welded to the washer or had long enough arms to reach up there with a wrench. Either way, the loctite is a good idea. However, I think it would become very obvious if the bolt started backing out of the nut. Things would get wobbly.
WarEagle1 #1381316 Sun Oct 18 2020 11:13 PM
ok thanks
Moderated by  Hambone
