The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 members (FAST55, Gray_Ghost, delky, 51sub, 78buckshot, 2 invisible), 138 guests, and 3 robots.
Forums60
Topics123,935
Posts1,000,132
Members44,787
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Wiring to/from Ammeter
#1377470 Fri Sep 18 2020 01:26 AM
Moderated
Hi folks. I'm the New Kid 😁. I'm resurrecting a '48 Chevy. Chevyofthe40s says it has an Ammeter NOT a voltmeter. And I therefore won't need a dropping resistor to use a 12V system. I want to use all original gauges. So QUESTION: Which post on the Ammeter gets 12V Positive and which do I ground?
There are no marks to indicate it and I am the 4th owner in trying to bring it to life. So I didn't take it apart. (I have a '49 Studebaker pickup, so I'm not all bad). Thanks in advance.
Kenneth R Brown
Re: Wiring to/from Ammeter
Kenny Who #1377477 Fri Sep 18 2020 01:55 AM
Moderator - The Electrical Bay and Rocky Mountain Bolters
Hello Kenny, please do NOT wire your ammeter to ground. I just saw a post that shows how they are to be wired, but surely someone else will chime in soon.
Also, please drop into the welcome forum and introduce yourself to the TRUCK FORUM, where car questions are usually sent to the greasy spoon to be resolved.
here is the link that will give you an idea of how things are normally wired! https://www.vintageautogarage.com/v/vspfiles/files/alt-wire-diagram-10.14.pdf
Another quality post.
Real Trucks Rattle
Kenny Who #1377602 Sat Sep 19 2020 02:51 AM
Might be a good idea to learn about simple electricity someplace to learn how it works, pretty simple, just a few basics would help.
Ammeters do not care about voltage, just flow, so, if one turns on the headlights or some other load with the engine off, the ammeter should indicate negative, if reads positive, just change the leads. The whole electrical load less the starter, should feed through the ammeter, lead goes from the starter large starter terminal directly to the ammeter to feed the whole rest of the truck, which gets fed from the other ammeter terminal.
Ed
Kenny Who #1381171 Sat Oct 17 2020 02:58 PM
Moderated
I just rewired my '49 Chevy 3/4 ton Step Van. The way I did it is I ran a 10 gauge wire from battery terminal on Solenoid to the D (Discharge) side of ammeter and a 10 gauge wire from D to St on ignition switch. Then with the same gauge wire I ran from bat. (battery) on ignition switch to C (Charge) side of ammeter. My ignition switch has 4 terminals (Bat., Acc., St., & Ing.) St. is in center with the others in a triangle shape. This worked for me.
Kenny Who #1382227 Mon Oct 26 2020 04:28 AM
I am seriously thinking about changing from my gen./reg. to a alternator. I keep hearing about a one wire alternator set up, meaning going from the alternator Bat. terminal straight to the battery. One would think there has to be more to it than isn't there?
Kenny Who #1382250 Mon Oct 26 2020 12:48 PM
AD Addict
I have a one wire alternator and it is that easy, but there are drawbacks. Here’s an article by Rod Authority that points out the differences. One Wire vs. Three Wire Alternators [rodauthority.com]
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Moderated by  Rusty Rod
