The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
18 members (55 SHAKER, Donf, 3B, drdoug, 66flea, Christian, 3 invisible), 198 guests, and 3 robots.
Forums50
Topics122,131
Posts979,681
Members44,158
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
what fuel pickup fitting do I need??
#1380883 Thu Oct 15 2020 07:40 PM
For my universal tank, I bought the fuel pickup that was required, and it came with no fitting. Where can I buy this fitting, and is it something I can just grab at Home Depot? All I need is a connector that I can connect the rubber fuel line to.
Below is the fuel pickup I had to buy to match the tank:
https://www.summitracing.com/parts/tnk-pta-g
I don't need a show quality connector. All I need is a part to get gas from my new tank into the fuel line, lol. I don't know how you custom rodders do it- this is making me batty!
Thanks!
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
Re: what fuel pickup fitting do I need??
pan3lman #1380893 Thu Oct 15 2020 09:04 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Most auto parts stores have a good supply of brass fittings.
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2)
ā€˜39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
pan3lman #1380899 Thu Oct 15 2020 09:27 PM
I agree with Martin...take the sender with you to your local parts store and they should have what you need...
Mike B smile
pan3lman #1380915 Thu Oct 15 2020 11:28 PM
Boltergeist
The specifications say "1/4" NPT" fittings. If you're planning on using a metal line from the tank to the front of the vehicle, you'll need an adapter fitting with a 1/4" male NPT thread and a 5/16" "female inverted flare" thread on the other end. That will allow you to install a pre-made 5/16" tubing gas line with the inverted flare fittings already installed. You'll probably need to plug one of the standpipe fittings and use the hose barb in the middle for a rubber vent line.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
pan3lman #1380921 Thu Oct 15 2020 11:49 PM
Thanks very much, guys. I'll run an op tomorrow.
pan3lman #1380940 Fri Oct 16 2020 02:21 AM
3B Online
Hy pan3lman, the Weatherhead part number for the straight 1/4 npt to 5/16 inverted flare is 202X5X4, hope that helps.
Hotrod Lincoln #1380978 Fri Oct 16 2020 11:39 AM
I bought a roll of aluminum fuel line to run the length of the truck to the engine. I don't have a flaring tool, so for the short term, I will need to run rubber fuel line between the tank fitting and the aluminum fuel line, and secure it with hose clamps.
3B #1380979 Fri Oct 16 2020 11:39 AM
Thank you!!
pan3lman #1380985 Fri Oct 16 2020 12:31 PM
7
I wouldn't run the aluminum line, you could use it for a temporary fix but with the labor you might as well run it in the more sturdy Bundyflex or copper-nickel. You will be better off getting a flare tool capable of making double flares and that way the normal inverted flare fittings used in fuel systems will be easy to find and use.
1957 Chevrolet 5700 LCF 283 SM420 single speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto
pan3lman #1380996 Fri Oct 16 2020 01:18 PM
Yup, may be able to get a used flare tool kit on Ebay, just make sure it will ship right away. Aluminum would NOT be my first choice. You ever seen the electrostatic corrosion between aluminum and brass? The aluminum turns into a white powder after a time. Aluminum oxide is good to keep under arms dry but not good with high processed fuels. Can get away longer with diesel applications but not gas. Good luck. Doc.
Currently making 1954 3100 better than new
Page 1 of 2 1 2
Moderated by  Woogeroo
