The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
20 members (Donf, 3B, 55 SHAKER, 66flea, Christian, 68ironhead, 3 invisible), 203 guests, and 3 robots.
Forums50
Topics122,131
Posts979,681
Members44,158
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Stovebolts in Boats
#1380610 Tue Oct 13 2020 05:16 PM
Weren't late Stovebolt engines, like the 292, used in inboard engine/outboard drive boats? Weren't they "hardened" because boats are run at wide-open-throttle all the time? Are these a source for engines in trucks?
1948 3/4-Ton 5-Window Flatbed Chevrolet [sandeace.com]
28 Years of Daily Driving but now on hiatus. With a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
Re: Stovebolts in Boats
Wally / Montana #1380650 Tue Oct 13 2020 08:36 PM
Shop Clutterist
Mercruiser i/o used the 194, 230, 250 and 292 engines.
A friend bought a new boat with twin Mercruiser 165s. He thought that since the engines were very common, parts would be cheap and easy to find.
Don't think I would want a marine engine for a truck. Even with fresh water cooling, the environment is harsh. Camshaft would be wrong. Carb would be wrong.
Gord
1954 1/2 ton 235 4 speed
Wally / Montana #1380652 Tue Oct 13 2020 09:02 PM
Didn't some of the marine engines rotate backwards?
Wally / Montana #1380653 Tue Oct 13 2020 09:05 PM
Boats with twin engines usually had a ccw and cw rotation.
1953 panel #1380658 Tue Oct 13 2020 10:09 PM
That would typically be done with the gearing in the outdrive unit, not modifying the engine to run backwards. Much easier to swap gears.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Wally / Montana #1380681 Wed Oct 14 2020 12:56 AM
As a kid growing up Mom and Dad owned a cabin cruiser and we spent almost every weekend on the boat. Many of the twin engine boats docked at the marina had V8's (GM, Chrysler, Merc's etc) with one reverse rotating engine.
Mike B smile
Wally / Montana #1380712 Wed Oct 14 2020 04:05 AM
7
We had a 3 litre Chevy 4 cylinder in a OMC I/O, rotation was clockwise as viewed from the front of the engine, Bore was the same as the 350, starter same as all the small blocks, I would assume the bell housing pattern would match all the Chevy transmissions, nothing real special except having to meet marine code for gas vapors and electrical arc suppression
1957 Chevrolet 5700 LCF 283 SM420 single speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto
Wally / Montana #1380716 Wed Oct 14 2020 06:58 AM
A fellow Stovebolter, Mapleleaf, grew up around boats with inline Chevy’s. Search his name here, and see if you can contact him. Very knowledgeable about this subject.
Wally / Montana #1380721 Wed Oct 14 2020 11:24 AM
1928 Chevy dump truck we put a 4cyl Mercruiser engine into. The Chevy I4, I6, V6 (90*), small block and big block V8 all had the same bell housing bolt pattern. The marine engine in something always under a pull, like a dump truck, works out very well. Don't know about a highway cruiser app.
[img]https://i.postimg.cc/G9rHvjPG/IMG-4658.jpg[/img] [postimg.cc]
[img]https://i.postimg.cc/t139gLMf/IMG-4656.jpg[/img] [postimg.cc]
Evan
Wally / Montana #1380753 Wed Oct 14 2020 04:31 PM
With the correct engine it is possible just don't use the marine generator or alternator, will cook the battery. Doc.
Currently making 1954 3100 better than new
Page 1 of 2 1 2
Moderated by  Woogeroo
