The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (LAJones48, buoymaker, jtroberts, Johnny N, Hotrod Lincoln, 53&Me), 224 guests, and 3 robots.
Forums50
Topics122,185
Posts980,150
Members44,168
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1937 216 Crankshaft Compatibility
#1380431 Mon Oct 12 2020 02:04 PM
Moderated
Good morning,
Long team reader...first time posting.
I have a Frankenstein 1950 3100. It has the Chassis of 1953, Cab of 1950 and soon to have a rebuilt 1946 216 Engine.
I have tried to do some research and I have not found a definitive answer.
I am in the process of rebuilding a 1946 216. It has a crankshaft that can be refurbished. However, I was able to acquire a NOS 1937 Crankshaft with matching Babbitt poured connecting rods. Here is my question: Will the 1937 Crankshaft work in a 1946 motor?
Here is some additional information:
The crank that came out of the 1946 engine has cast of 839775.
The cast for the 1937 Crank is 838877.
Per the Master Parts Catalog the replacement numbers do not match, so I am assuming the answer is no. Hoping there may be a work around though as it will save some $.
Thanks in advance for your help.
Re: 1937 216 Crankshaft Compatibility
Davey Whiplash #1380888 Thu Oct 15 2020 08:00 PM
Moderated
I must of really stumped everybody. Nobody has a hypothesis?
Davey Whiplash #1380929 Fri Oct 16 2020 01:04 AM
Davey
I do not know the answer to your question. But, based on my experiences with my ‘37 and ‘46, added to the info you provided from the Master Parts Catalog, my guess is this swap will likely end in more expense of time and money than finding correct replacement parts.
Good Luck.
Davey Whiplash #1380930 Fri Oct 16 2020 01:06 AM
Boltergeist
My specifications on 216 crankshafts don't go back into the 1930's. I do have diameter specs on 216's from the 1946 engine, which has wider connecting rod big ends that the 48-53 models, I believe. My Federal-Mogul shop specifications manual lists the connecting rods that fit the 839775 crank as having a width of 1.240". You might try measuring the rods for the earlier crank to see if they have a different width. Also, measure the main bearing diameter and the width of the #3 (thrust) bearing to see if those dimensions match up. The main bearings have 4 different diameters, with the shaft size getting bigger toward the rear.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Davey Whiplash #1380945 Fri Oct 16 2020 02:57 AM
1940 was the first year for a rear main seal. Before that they used a slinger. The 1937 crank will not fit the later engine.
My Blog
Davey Whiplash #1380947 Fri Oct 16 2020 03:22 AM
Moderated
Thank you everyone for your feedback. It really helped. I will use the existing crank. Guess I’ll put the NOS crank out on the swap section.
This truck has been a blast to work on! Learning tons.
Thanks again.
Moderated by  Woogeroo
