The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (Jon Patton, Phak1, papas52, Justhorsenround, RP14, 1 invisible), 116 guests, and 3 robots.
Forums60
Topics123,919
Posts1,000,037
Members44,782
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Steering Wheel Instruction
#1380246 Sat Oct 10 2020 03:17 PM
Excerpt from the 47-54 Factory Assembly Manual . Can somebody tell me if the Hub Cover Assembly 3701357 is supposed to be on a 51 3100?
1951 Chevy 3100 5-window
261 cu in, 348 Head, Split Fenton Exhaust
Offy with Dual Weber 2 Bbl Carbs
Re: Steering Wheel Instruction
51bowtie #1380251 Sat Oct 10 2020 04:01 PM
As you know, the 47-54 Factory Assembly Manual is actually for 1954/55st Chevrolet trucks.
And, as you know, the steering wheel and the steering column changed in 1954.
And, as you probably know, the 47-53 Shop Manual does not show what is under the steering wheel (at the "joint between the steering column and the steering wheel).
You are asking the right question. Maybe someone will post a photograph?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
51bowtie #1380258 Sat Oct 10 2020 04:58 PM
Don't have a pic, but there's no hub cover assembly below the steering wheel on my '51. The steering column tube is straight from the bottom to the underside of the steering wheel.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
51bowtie #1380259 Sat Oct 10 2020 05:03 PM
If this helps, this is a '49. Doesn't look like any hub on this either. If it stops raining I can go out and take the cover off to get a better photo, I am hoping to drive it today anyway.
1949 Chevrolet 3/4 Ton - Still Solid.
51bowtie #1380263 Sat Oct 10 2020 05:33 PM
All good info. Any idea why the horn blows without any steering wheel internals?
51bowtie #1380264 Sat Oct 10 2020 05:35 PM
Crossover to the Horn Relay topic.
51bowtie #1380266 Sat Oct 10 2020 05:40 PM
NorthCoast3800 #1380267 Sat Oct 10 2020 05:44 PM
Same look as the 51. Thanks
51bowtie #1380274 Sat Oct 10 2020 08:27 PM
Is the wire that runs inside the column removed as well? That could easily be shorted to ground. Woven insulation cover may be rotted away and the vinyl insulation brittle, cracked, and flaking off.
klhansen #1380275 Sat Oct 10 2020 09:00 PM
That wire is free and not making contact.
Page 1 of 2 1 2
Moderated by  Justhorsenround
