The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (Coy1, lumbersawyer, Phak1, moparguy, stlcardinalsguy, jock), 107 guests, and 7 robots.
Forums60
Topics123,917
Posts1,000,027
Members44,782
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Horn Relay
#1380100 Fri Oct 09 2020 02:22 PM
Going to install a horn relay in my 51. Its marked with the following numbers: 30, 85, 86, 87. Whats the proper makeup for this relay?
1951 Chevy 3100 5-window
261 cu in, 348 Head, Split Fenton Exhaust
Offy with Dual Weber 2 Bbl Carbs
Re: Horn Relay
51bowtie #1380102 Fri Oct 09 2020 02:27 PM
By the way, they are aftermarket modern horns.
Re: Horn Relay
51bowtie #1380104 Fri Oct 09 2020 02:35 PM
What brand & model-number horn?
What brand & model-number relay?
And/or post/attach photos of both.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: Horn Relay
tclederman #1380111 Fri Oct 09 2020 02:57 PM
Both are Hella Products. The relay is model 960 388-46. 12v
Re: Horn Relay
51bowtie #1380112 Fri Oct 09 2020 03:04 PM
Moderator - The Electrical Bay and Rocky Mountain Bolters
Here is a typical installation absconded from the googler.
Another quality post.
Real Trucks Rattle
Re: Horn Relay
Rusty Rod #1380114 Fri Oct 09 2020 03:13 PM
Looks like what I need but....the relationship between the 85 terminal and the 30 terminal. Is it saying I need to jumper the two terminals?
Re: Horn Relay
51bowtie #1380126 Fri Oct 09 2020 04:18 PM
Yes, although you could power each one separately from different circuits.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Re: Horn Relay
51bowtie #1380159 Fri Oct 09 2020 08:54 PM
The relay is a Bosch relay. The attached is similar to Rusty Rod's diagram, but shows the internals of the relay.
don
Re: Horn Relay
51bowtie #1380166 Fri Oct 09 2020 10:10 PM
Hooked everything up per all the info I got and the horn continually sounds. Figured if was something in the steering column. Took it apart and stripped it. The horn still sounds! WTH?
Moderated by  Rusty Rod
