The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (ccanepa50, loekey53, artinva, homer52, Hotrod Lincoln), 191 guests, and 4 robots.
Forums50
Topics120,921
Posts969,322
Members43,791
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Tractor Question
#1378624 Sun Sep 27 2020 02:08 AM
Have any of you fellas ever straightened a bent rod on a hydraulic cylinder. Somehow I managed to bend a couple on my Kubota. Kubota wants $900 for each cylinder, and about that just for the rods. A local hydraulic expert will make me a new one for $200, but I found a Harley shop that thinks he can straighten it to 7 thousands tolerance. Anybody got any experience with one of these?
Allen
1974 Stingray Corvette
Re: Tractor Question
Allen Lane #1378643 Sun Sep 27 2020 09:47 AM
Over the years of being a Maintenance Machinist, I have straightened hundreds of rods and pump shafts.
If it can be done, depends on the size of the shaft and how bad it is bent.
A press and an indicator is a must have to even try it. I also think that .007 is very doable.
< .003 would not be that hard either, if you know what you are doing.
Look at it this way, you don’t have anything to lose if you try it.
Don
"The Flag Pole"
In the Stovebolt Gallery [stovebolt.com]
More pix on Photobucket [s893.photobucket.com]
'46 2-Ton grain truck
'48 3/4-ton grain truck
'50 2-ton flatbed
'54 Pontiac Straight Eight
'70 American LaFrance pumper fire truck.
Allen Lane #1378645 Sun Sep 27 2020 09:52 AM
A youtuber named Johnathon w did it.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery
2017 Buick Encore
Pix on Photobucket
Allen Lane #1378657 Sun Sep 27 2020 01:25 PM
Hey Allen,
Are you talking about front end loader cylinder rods? I have successfully straightened them on an old MF I had years ago. I am not a machinist. A press is essential as well as some real hard wood to keep from scratching/gouging the rod.
Allen Lane #1378682 Sun Sep 27 2020 04:54 PM
Workshop Owner
If you decide to have them straightened, make sure who ever does the work knows what they're doing. Otherwise they can make them worse.
Quote
I agree. Like Don said, it also depends on how bad they are bent.
Just curious on which Kubota you have, and how you bent them as I also have a Kubota and don't wish to experience the same problem.
J Lucas
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
1959 Chevy Apache 31 Fleetside
1959 Chevy Apache 32 Fleetside
1959 Chevy Viking 40
My Flicker Photos! [flickr.com]
Paul_WNC #1378731 Mon Sep 28 2020 12:52 AM
Paul, yes....the bucket rotate cylinders. I dropped 'em off at the Harley shop, he had all the equipment...we'll see how he makes out.
Allen
J Lucas #1378732 Mon Sep 28 2020 01:05 AM
John, I've got the 3130 HST with a LA513 FEL. I'm not sure how I bent them. I think it was a while ago and the small bends finally wore out the seals which was dumping fluid. These are darn tough machines, I've lifted huge tree trunks, truck cabs, and lot's of dirt, so not sure.
Allen
Allen Lane #1378743 Mon Sep 28 2020 02:08 AM
Workshop Owner
I've done the same with mine, lot's of big trees, dirt, road rock, AD and Art Deco cabs engines etc. and so far no problems. I have a B7800 HST 4 cylinder 30 hp with a LA402 FEL, it's a little smaller and lighter duty machine, but like yours it's darn tough.
Hope you get them straightened.
J Lucas
1941 Chevy 1/2-Ton
Allen Lane #1378744 Mon Sep 28 2020 02:12 AM
jdl Offline
Ive never personally had them straightened but we'll send them out if the customer wants it, haven't heard any horror stories. Something to think about though if they've bent once and you bend them back straight, it probably won't take as much force to bend them again.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
Allen Lane #1378762 Mon Sep 28 2020 09:59 AM
We have steel V blocks with a layer of brass run over the notches. This seems to help stop the twisting when the ram makes contact. I would think a notch would also help if using wood. For really long shafts that don't fit the press bed we have a puller instead of a pusher ram. There is a hole in the 5' x 10' x 3/4" welding/jig table that the hook on the puller ram can reach through. With V blocks set on the table surface I guess we could handle a 60ft long shaft (width of shop building) with the puller ram set up. It is surprising how much we use the press, table, and ancient huge Monarch flat belt lathe for straightening various parts on the old rides we work on.
Evan
Page 1 of 2 1 2
Moderated by  Bouncer, Justhorsenround, Tiny
