The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (bluesman, DS1957GMC, Abelsclassic, artinva, 3B, 1 invisible), 190 guests, and 3 robots.
Forums50
Topics120,957
Posts969,687
Members43,802
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
1950 "Crew Cab" conversion
#1378472 Fri Sep 25 2020 11:59 PM
ace skiver
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: 1950 "Crew Cab" conversion
tclederman #1378476 Sat Sep 26 2020 12:10 AM
A lot of work there, but the interface between the front and back doors looks funky. A sharper upper front corner on the back doors would look better for sure. The roofline interface is also strange looking, but that may just be the fact that the added sheet metal is bare versus the painted roof portions.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
tclederman #1378477 Sat Sep 26 2020 12:17 AM
ace skiver
Yes, it is hard to visualize how true the top edges of the two door's windows/openings lineup?
Tim
tclederman #1378480 Sat Sep 26 2020 12:22 AM
Almost looks like the doors lean toward each other, possibly the whole cab is lower in the middle, but may be an optical illusion.
tclederman #1378499 Sat Sep 26 2020 03:15 AM
I noticed that the drivers side looks better or more square than the passenger side. Roof curve is wonky also on passenger side. I think the doors could of been more square to each other on that side also. ohwell
tclederman #1378536 Sat Sep 26 2020 02:34 PM
AD Addict
Looks like the new owner may have a bit of an issue aligning the passengers side rear door. The belt line and top of the door is too low and at the same time the gap at the front of the door seems good. Could be an illusion, but one has to wonder why they only took it this far.
I like the concept but not the implementation.
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
tclederman #1378560 Sat Sep 26 2020 05:25 PM
ace skiver
I think the angles and the lighting make it hard to discern the quality of that nice job.
Look at image berlow - everything seems to line up.
Tim
tclederman #1378611 Sun Sep 27 2020 12:43 AM
I think I said basically the same thing about the lighting (bare metal vs. painted).
But I don't care for the way the pillar between doors gets wider at the top.
It is way above my skill level though.
tclederman #1378615 Sun Sep 27 2020 01:22 AM
There is an extended cab that was built with factory provided metal for fire trucks in 1950
One was for sale last year up in Saskatchewan, it would be the correct way to get that 4 door without weird illusions and a lot of metal work
They come up once in a while
I have photos somewhere
Much better than this home project on eBay.
-s
tclederman #1378625 Sun Sep 27 2020 02:15 AM
ace skiver
A Special Order 1954 COE Crew Cab is attached below.
Tim
Page 1 of 2 1 2
Moderated by  Tiny
