EVENTS
Check in for status!
Jump over to the
Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
2 members (GeorgeCz, 1 invisible),
182
robots. |
Key:
Admin,
Mod
Forums50
Topics122,227
Posts980,553
Members44,189
Most Online1,229 Jan 21st, 2020
 1952 Chevy 3100 - LS swap keep foot starter
OP
Hey everyone,
I'm not at this stage yet in my build, but I had a question that I was unable to find anywhere. I love the foot starter concept, but I wasn't sure if it was possible to keep this with an LS swap. I'm looking to put in a LQ4, and I would LOVE to keep the factory ignition with the foot stomp. Has anyone here kept theirs?
Thanks, Bret
1952 Chevy 3100 - currently apart and hogging up the garage.
 Re: 1952 Chevy 3100 - LS swap keep foot starter
Moderator - The Electrical Bay and Rocky Mountain Bolters
You should just need to re-route the starter solenoid wire through a "stomp" switch from the key switch or wherever your solenoid power is coming from.
Another quality post.
Real Trucks Rattle
I think Hot Rod Lincoln has the number for a tractor starter switch that you can mount the factory stomp starter pad to and once the bellows is in place it's undetectable (PM him). On my Buick (floor foot feed to start) and my Studebaker PU (push clutch pedal down firmly to start) I immediately converted them to key start and did away with two switches and associated wiring.
Evan
OP
Fantastic news guys! Thanks for the info! I'm glad that it's in the realm of possibilities!
Boltergeist
Try a website such as TSC (Tractor Supply Co.) and search for a starter switch for an N-series Ford tractor. (9N, 3N or 8N) It can be mounted to the floor in the position the foot start linkage would normally occupy, and the original pedal button can be adapted to the switch and covered up by the OEM rubber pedal accordion. It's very hard to tell it from the original mechanical linkage without a close inspection. https://www.tractorsupply.com/tsc/product/tisco-starter-switch-dr405c?cm_vc=-10005Have fun! Jerry
The murder victim was drowned in a bathtub full of Rice Krispies and milk. The coroner blamed the crime on a cereal killer! Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
Check out barnfind49 he has the stomp starter on his .there is a video on one of his posts
OP
Try a website such as TSC (Tractor Supply Co.) and search for a starter switch for an N-series Ford tractor. (9N, 3N or 8N) It can be mounted to the floor in the position the foot start linkage would normally occupy, and the original pedal button can be adapted to the switch and covered up by the OEM rubber pedal accordion. It's very hard to tell it from the original mechanical linkage without a close inspection. https://www.tractorsupply.com/tsc/product/tisco-starter-switch-dr405c?cm_vc=-10005Have fun! Jerry Okay I'll check that out for sure. Thanks for that! Check out barnfind49 he has the stomp starter on his .there is a video on one of his posts Checking that out now.
Workshop Owner
FYI: I bought one last night to have on hand for an upcoming project at the local TSC. They had 2 in stock at $12.99 each. Thanks for the info. Jerry.  John
J Lucas 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWB 1959 Chevy Apache 31 Fleetside 1959 Chevy Apache 32 Fleetside 1959 Chevy Viking 40 My Flicker Photos! [flickr.com]
