The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 members (Hotrod Lincoln, 2ManyTrucks, 3B, 58n63, 2 invisible), 244 guests, and 0 robots.
Forums50
Topics122,214
Posts980,446
Members44,177
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 4 1 2 3 4
Re: 51 3100 Ignition Switch
51bowtie #1378034 Tue Sep 22 2020 10:47 AM
General Purpose
Sure like to see these switches.
Watch out for careful drivers!!!
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
You can't teach a new dog old tricks.
bartamos #1378063 Tue Sep 22 2020 03:01 PM
Come on down (or Up).
1951 Chevy 3100 5-window
261 cu in, 348 Head, Split Fenton Exhaust
Offy with Dual Weber 2 Bbl Carbs
51bowtie #1378096 Tue Sep 22 2020 06:47 PM
General Purpose
Pics.
51bowtie #1378105 Tue Sep 22 2020 08:18 PM
Originally Posted by 51bowtie
I have converted to 12 volt and I do have the Diagram you attached. Just trying to figure where everything goes. Also does the switch turn off to ?the right or to the left?
If you have the correct housing and ignition turning the key to the right from the center Position should be off and you can remove the key
If you can turn your key either left or right from center position then you probably have an incorrect part.
Probably have the housing for the no-key feature, the no-key switch has a little handel On it
Can you can post a pic of your set up? I have both type housings And can compare them
In any case just wire it per your 12 volt conversion kit
51bowtie #1378118 Tue Sep 22 2020 09:21 PM
Just checked everything for the umpteenth time and here is what I have: By the way, both switches are IDENTICAL in their form...not so in their function...and both ARE two position.
Original Switch: Off is CCW. Turn CW to Continuity . Key comes out in the OFF position.
Replac, Switch: Off is CW. Turn CCW to Continuity, Key ONLY comes out if the ON position (so much for anti theft).
Think I will send the replacement back.
51bowtie #1378148 Wed Sep 23 2020 12:47 AM
General Purpose
DADS50. When someone says right or left of center position, I think of a three position switch. Left-Center-Right. That's why we are referring to a two position switch as CCW ON or CW On. There is no center position on a two position ON/OFF switch. Please clarify. Bowtie says his switches are two position. Both have keys. I did not know there was a CCW ON, two position switch, for our trucks or any vehicle in our era. Learned something here. But Very Very odd even if switch is left of column.
51Bowtie: The reason we are asking for pics is for us and the next person with this issue. We will be able to better help them if we see these switches. We can then identify CCW ON switches and CW ON switches and etc. This post and all posts are used for the search function and for helping future Stovebolt members. You will be helping the knowledge base here. If you would also post the vendor and part number of the ones you purchased it would greatly help. We have tried to help and given you are best, we ask that you reciprocate with these follow up requests. (pictures and part numbers)
DADS50 can also post his comparison switches and his valued opinion.
51bowtie #1378152 Wed Sep 23 2020 01:00 AM
This switch can be switched off by either turning key to the left or right [youtube.com]
I may have been thrown off by the him saying turning key to the left for off.
Here is a quick pic of the two different housings
[img]https://www.stovebolt.com/ubbthread...F2E989D-DFF3-4D38-B22F-D9FA7652F9F2.jpeg[/img]
51bowtie #1378159 Wed Sep 23 2020 01:17 AM
General Purpose
I'm not catching on to this. No one is making any sense to me. I don't think there is a two position switch available for our trucks that has off at CW. NONE! ZERO! Stop the madness. If you think you have a switch like that, you are nuts. Like in the head.
It does not matter to me if the key pulls out or where it pulls out. Don't care about lever handle or not. They are ALL off at CCW. There is a lot of misinformation going on here and bogus testing. I wish someone would be on my wave length here. Holy Moses. I need some back up, over? I'm fixin to do a a six pack of Foster's (Large Format) if no help is coming.
51bowtie #1378160 Wed Sep 23 2020 01:24 AM
There are actually two ignition switches for AD trucks. One for 47-48 with the tab on the cylinder PN 1116452, and another for 49-54 without tab PN 1116464.
I don't know if there's a difference in how they work (that's the early switch in Dads50's video), or if the early one is even available as a repop. I can't see a real difference in Dads50's pictures of the switch bodies, other than the position of the cylinder removal plunger.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
51bowtie #1378161 Wed Sep 23 2020 01:33 AM
General Purpose
Page 2 of 4 1 2 3 4
Moderated by  Rusty Rod
