The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 members (elhippie64, dougs, 68ironhead, 49nut, D B Cooper, Duwop), 170 guests, and 3 robots.
Forums60
Topics124,646
Posts1,006,079
Members44,991
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Power steering
#1376019 Sat Sep 05 2020 04:27 PM
Moderated
Has anyone changed to power steering on their 1954 3800 1 ton?
Thanks for any help
Re: Power steering
Dually54 #1376355 Tue Sep 08 2020 12:19 PM
Unrepentant VW Lover
Sorry about the late response .... could be that all the gang were out over the weekend ... smile Anyway, I have not. But I always ask the question: Why do you want to?
If you want to do it because you want to do it, or you have a medical/physical reason ... then by all means. But if you think you need to do it to get "better" steering .... In my own limited experience on three restorations, I have found that rebuilding the steering box, replacing the tie rod ends and king pins, and getting everything in adjustment (all things you'd want to do anyway) provides steering *almost* as easy and comfortable as power steering at a fraction of the effort, expense and fabrication. In my current truck (1949 3804), I routinely drive 60-65 mph with original steering (adjusted, naturally). I even run bias ply tires. Steering is solid. Even at a crawl in the parking lot, it isn't too bad. Not one finger, but certainly one hand.
But like I said, if you *want* to do it, then have at it. But you don't *have* to do it for better steering -- just rebuilding and adjusting what you already have will get you 85 to 90 percent of what power steering would do for you.
Food for thought.
"Of all tyrannies a tyranny sincerely exercised for the good of its victims may be the most oppressive."
— C. S. Lewis
'49 Chevrolet 3804
Re: Power steering
Dually54 #1376468 Wed Sep 09 2020 05:34 AM
Fox Offline
I second John. I run radials on my 51 GMC one ton and have a similar steering feel. However, on very grippy pavement at a stop is another sorry. Once inching along, it eases up a lot.
In the Stovebolt Gallery [stovebolt.com]
More pictures here [photos.app.goo.gl]
1951 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- Rusty- the puzzle box lid for the C10.
1950 Chevrolet 1300- in progress to shiny.
1962 AMC Rambler American- my wife’s
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
Re: Power steering
Dually54 #1376507 Wed Sep 09 2020 04:34 PM
I'm running 19.5 radials on my 51 chevy 1 ton with stock steering and it drives like a dream, If anything it may steer a little to easy. It took some getting use to when I first put them on.
Re: Power steering
Dually54 #1377014 Mon Sep 14 2020 05:18 PM
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery
2017 Buick Encore
Pix on Photobucket
Re: Power steering
Dually54 #1378026 Tue Sep 22 2020 05:12 AM
I have thought about adding PS to my '51 from time to time but where to put the PS pump has stymied me. I used the original generator mount for an A/C compressor and above that is the alternator. On the passenger side of the engine there just isn't anything to bolt a PS pump on to. No head bolts show outside the valve cover, no motor mount bosses on my engine. So I just have to lift weights between trips.
51 3800 PU, 55 235 (w/cam, headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971.
Re: Power steering
Dually54 #1378166 Wed Sep 23 2020 01:46 AM
Moderated
Thank you guys for the response.
Re: Power steering
1Ton_tommy #1378173 Wed Sep 23 2020 02:02 AM
Red dot, center of chest ...
I investigated this at one time. There's a way to get electric-assisted power steering, which eliminates the need for a power steering pump and all the associated problems with hydraulics and hydraulic oil. You'll have to research what's best/easiest for you to implement.
Electric Power Steering [ebay.com]https://www.ebay.com/motors/blog/convert-your-classic-to-electric-power-assist-steering/
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
Moderated by  Grigg
