The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (tom moore, larrylowe, tomctomc), 169 guests, and 3 robots.
Forums50
Topics120,922
Posts969,326
Members43,791
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Oversize Kingpin Kit Part number?
#1377430 Thu Sep 17 2020 04:39 PM
I've been at this for hours and need a little help. None of my local auto parts stores can find anything and the search function isn't returning part numbers either.
I'm having my 1946 2 ton axle rebuilt now and I need an oversized kingpin rebuild kit. Anyone know the part number? My pin diameter is 1.109" and I need .010" bigger because the eyes on my axle are wallered out!! (oblongated??)
Alternatively If anyone has the stock sized kit part number I could potentially use that kit but the machinist would still have to fabricate oversized pins.
I've checked ebay, the local NAPAs, Rare Parts etc and am striking out.
Re: Oversize Kingpin Kit Part number?
Brian46Chevy #1377432 Thu Sep 17 2020 05:03 PM
ace skiver
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
tclederman #1377435 Thu Sep 17 2020 06:20 PM
That seems like a very user friendly website, but I didn't find it listed anywhere and I experimented with other years etc.
Brian46Chevy #1377460 Thu Sep 17 2020 11:28 PM
Is this what you're looking for? I don't know enough about your 1946 2 Ton (is it chevy? is it GMC?) to know for sure. Maybe someone else can chime in.
1946 GMC King Pin Set with 1.118" Diameter Pin [shop.rareparts.com]
-David
1953 2-Ton GMC
Horsepower determines your speed when you hit the wall. Torque determines the size of the hole you make...
Brian46Chevy #1377490 Fri Sep 18 2020 04:37 AM
3B Offline
Hy Brian46Chevy, could you post your serial number please? I find two different 1.109" diameter king pins in 1946 trucks, my 1980 TRW Chassis Parts catalogue lists their part number K129N which is 6.75" long and K391C which is 6.34" long. Unfortunately there are no .010" oversize pins available. My suggestions would be to have your machinist bore the axle substantially oversize and make up a bushing bringing the axle kingpin bore back to standard size. You could also look for another axle in better condition, or have Rare Parts make you a custom set of kingpins, hope that helps
Brian46Chevy #1377491 Fri Sep 18 2020 04:47 AM
3B Offline
Hy Brian46Chevy, More research has yielded a Euclid part number E-4430B10 which has the dimensions of 1.119" X 6.34" and uses a centered single drawkey, hope that helps.
3B #1377970 Tue Sep 22 2020 12:25 AM
Hey 3B my sn is 6pw h 3153 Chevrolet
3B #1377985 Tue Sep 22 2020 01:31 AM
I couldn't source or cross that part so I paid way too much and ordered from Rareparts.com
I'm hoping that is the correct part but the guy on the phone at rareparts said they didn't have it/couldn't get it but I could email another employee to get a bid on them custom making the kit for me.
Brian46Chevy #1378004 Tue Sep 22 2020 02:22 AM
3B Offline
Hy Brian46 Chevy, okay more research has yielded a few more part numbers, the Euclid p/n E-4430B10 interchanges with Dayton 300-108, Moog 8490T+10, FM/TRW K391C+10, you should be able to get someone to track down one of those part numbers if you haven't already made a deal with Rare Parts, hope that helps.
Brian46Chevy #1378010 Tue Sep 22 2020 02:53 AM
3B Offline
Hy Brian46Chevy, okay I crossed E4430B10 at Napa and came up with their part number NCP 2621475010, unfortunately there are no specifications on the page and their picture shows a kingpin with two slots, but only one drawkey per kingpin, call them and see if you can confirm dimensions and availability, good luck.
Page 1 of 2 1 2
Moderated by  69Cuda, Grigg
