The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (Fox, latroca52, DennisM, DakotaSon1945, 1 invisible), 267 guests, and 4 robots.
Forums60
Topics123,438
Posts996,158
Members44,664
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 4 1 2 3 4
51 3100 Ignition Switch
#1377592 Sat Sep 19 2020 12:11 AM
I've managed to screw up my ignition switch wiring big time. As you know, the 3100 switch is not marked for terminals and where they go. So I have traced everything back and here is what I have. I am ASSUMING that the two terminals on the switch are facing up and the single terminal is facing below. I have traced the following: To Coil +, to Elec Fuel Pump, to Gas Gauge, to Batt, to Ammeter + . Can someone tell me where the wires go? (assuming is have the orientation correct)
1951 Chevy 3100 5-window
261 cu in, 348 Head, Split Fenton Exhaust
Offy with Dual Weber 2 Bbl Carbs
Re: 51 3100 Ignition Switch
51bowtie #1377601 Sat Sep 19 2020 01:34 AM
AD Addict
The original switch, as you know has three terminals, but only two were used. When you turn on the switch, it powers both the ignition terminal and the other terminal (maybe for accessories) and when you turn off the switch, it disconnects the power to both. You can use a multimeter to see how each terminal is powered.
I’ve included a picture of the electrical diagram for a ‘51. Keep in mind that if you converted to 12 volts the wiring will be a bit different.
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Phak1 #1377604 Sat Sep 19 2020 03:05 AM
I have converted to 12 volt and I do have the Diagram you attached. Just trying to figure where everything goes. Also does the switch turn off to ?the right or to the left?
51bowtie #1377612 Sat Sep 19 2020 04:00 AM
Sir Searchalot
Most all USA rotary on/off switches are CCW to off.
Does not matter which terminals are used on that switch as long as the hot feed is alone on one terminal. The other two are for everything else that is supposed to have "switched hot". Generally you would wire the switch per the wiring diagram. The 12V conversion has a few things different than on that diagram, as well as the electric fuel pump wiring.
Your switch works as follows. The 3 terminals have no continuity when switch off. Same 3 terminals have continuity when switch on. This can be confirmed quite easily with all wires disconnected and an ohm meter used. (continuity tester)
Watch out for careful drivers!!!
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
You can't teach a new dog old tricks.
51bowtie #1377896 Mon Sep 21 2020 04:21 PM
The Plot thickens. I have two supposedly identical switches. One tests for continuity going CCW and the other test for continuity going CW. I currently have the CCW to ON and my ammeter is constantly the hot lead so I put that on one terminal alone. Everything else got divided among the balance of the two terminals. With the ignition switch to ON, the electric pump comes on and everything seems copacetic .....except my Tach stopped working. WTH?
51bowtie #1377904 Mon Sep 21 2020 05:59 PM
CCW ignition switch = Theft deterrent.
Either that or it was for a right-hand drive vehicle, operated with the left hand. wink
Recheck how your tach is connected. Must be something else other than the weird ignition switch.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
klhansen #1377918 Mon Sep 21 2020 07:12 PM
Hmm, a good explanation why my Suburban's switch is wired "backwards"/incorrectly (for a few decades).
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
51bowtie #1377927 Mon Sep 21 2020 08:20 PM
Sir Searchalot
Remember, I said USA On/Off switches are CCW to off. That means a two position switch made for USA auto in the Stovebolt eras. Some three position switches could have accessory at CCW. I assume your switches are two position. Someone would have to show me a USA automotive two position switch with CCW as "ON" for sale.
When I said CCW to off, I meant at CCW, switch is off. 51bowtie: you said "I currently have the CCW to ON". Does that means the switch is ON when at CCW? That would be a crazy switch to use. The danger of leaving switch ON, over rides any theft deterrent.
51bowtie #1377931 Mon Sep 21 2020 08:35 PM
If it's a 3 position switch with left to right positions of ACC - OFF - ON, that might explain why the tach doesn't work if it's hooked to the ignition terminal and everything else is hooked to accessory terminal. Does it run with the switch all the way CCW?
51bowtie #1378008 Tue Sep 22 2020 02:34 AM
Believe Me. Both are two position switches. Weirdest thing I ever seen. CCW to Off or CW to Off, you can only get the key out in the OFF position.
Page 1 of 4 1 2 3 4
Moderated by  Rusty Rod
