The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (latroca52, tom moore, NorthCoast3800, chuck2213, walle, 1 invisible), 159 guests, and 3 robots.
Forums50
Topics120,964
Posts969,728
Members43,804
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1940 1/2 ton Pickup interior colors
#1377851 Mon Sep 21 2020 02:52 AM
Rabaut Offline OP
I’m getting ready to choose the paint color for the interior of my truck.
The outside is some shade of Brewster Green
Is the entire cab painted the same color... inside and out?
The outside color is used for the jams, floor, seat pan, inside firewall etc... underneath the trim panels?
Are the inside trim pieces, door panels, back wall panels, dashboard all painted the same color?
What is the most common color?
How about the headboard? Was that painted the interior color?
What would the color be? If not painted, what does it look like?
The instrument gauges are painted a tan color (or decal color).
What color is the surrounding plate?
Should that be the same as the other painted trim panels and dashboard?
Mike
1940 Chevy 1/2 Ton presently in pieces...
1940 Chevy Business Coupe
Re: 1940 1/2 ton Pickup interior colors
Rabaut #1377855 Mon Sep 21 2020 03:58 AM
Here's' some info on interior color.
1940 1/2 ton paint scheme
Everything inside would be painted the same color. On AD (47-54) trucks the demarcation between interior and exterior would be at the door weatherstripping. I'm assuming it would be the same for the earlier trucks. As a point of interest, I was just looking at my original gas tank, and apparently it was installed prior to interior paint because it was painted interior color.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Rabaut #1377873 Mon Sep 21 2020 12:52 PM
ace skiver
Another way to state where the paint-color "demarcation point" is on a truck/cab that has no weather seal/stripping installed:
The outer color ends where the outer skin (sheet metal) ends (over the inner sheet metal).
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Moderated by  HandyAndy, klhansen
