The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (drdoug, crenwelge, 2manyprojects, 3 invisible), 167 guests, and 3 robots.
Forums50
Topics121,009
Posts970,108
Members43,813
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 3 1 2 3
Re: Engine timing 180 degrees out and it runs
5253chevyman #1377769 Sun Sep 20 2020 05:55 PM
Keys and woodruffs can shear and do, now and then.
5253chevyman #1377791 Sun Sep 20 2020 08:34 PM
General Purpose
Try your timing light on each wire and see where it flashes on the marks.
Watch out for careful drivers!!!
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
5253chevyman #1377801 Sun Sep 20 2020 09:53 PM
Dumb question, but you are putting the timing light on #1 plug wire? Right?
5253chevyman #1377802 Sun Sep 20 2020 10:01 PM
General Purpose
smile Actually, that is a very good question. Holy Guacamole!!!!!!!!!
5253chevyman #1377810 Sun Sep 20 2020 10:32 PM
One more time: GET A TOP DEAD CENTER WHISTLE. Very cheap and goof proof for the hobbiest or ones without a lot tools/experience. Do a "tdc whistle" search and watch the video on how easy and accurate one is.
Evan
5253chevyman #1377811 Sun Sep 20 2020 10:36 PM
General Purpose
Your thumb is always with you. May the "Force" be with your no. 1 cylinder.
5253chevyman #1377817 Sun Sep 20 2020 11:32 PM
ace skiver
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
glenns towing #1377832 Mon Sep 21 2020 01:00 AM
Yes I am putting the timing light on plug wire #1. Not my first rodeo. Will do more research next weekend. after I find TDC and position of distributor will know more. May have to pull harmonic balancer and re-key to align timing mark to TDC.
Chevy Pete
5253chevyman #1377835 Mon Sep 21 2020 01:07 AM
General Purpose
The comments and suggestions are not meant to disrespect. A thorough diagnosis always starts with the basics. We don't know what anyone has missed. Experienced or not. It should be fairly easy to see if keyway in balancer is matched with keyway on crank. flashlight, mirror, whatever. As I said before if it slipped or sheared key, it would not slip exactly 180 deg. The odds are 360 to 1. Not counting the "minutes". That would be 21,600 to 1. Good luck next weekend.
Be sure and come back and tell us what you find is wrong.
5253chevyman #1378157 Wed Sep 23 2020 01:14 AM
You are not 180 degrees out, your marks are off. Rotate engine with plugs out, when number one pushes out air, that is TDC for number one.
Ed
Page 2 of 3 1 2 3
Moderated by  Rusty Rod
