The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 members (crenwelge, 2manyprojects, 4 invisible), 159 guests, and 3 robots.
Forums50
Topics121,009
Posts970,109
Members43,813
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Air Bag Impact Sensor - 2006 GMC Sierra
#1372019 Tue Aug 04 2020 02:30 AM
A couple of years ago, one of the front air bag impact sensors went out on my GMC. I got out my scan tool and found that sensor 1 (driver side) was bad. I replaced it thru NAPA for approximately $135.00 with an employee discount. I think they retail for some where north of $330.00.
Last week, sensor 2 (passenger side) went out. I purchased a used OEM sensor on EBay for $45.00, with a money back guarantee. The front impact sensors are located on a cross member that's covered with a plastic shield. These things seem to corrode from the inside to the outside and are known to fail for no good reason at all. It's a terrible design in my opinion. Anyone have a good source on these over-priced little gems?
Andy
His: 1947 Chevrolet 3104 [flic.kr]
Hers: 2008 American Saddlebred [flic.kr]
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
Re: Air Bag Impact Sensor - 2006 GMC Sierra
HandyAndy #1377632 Sat Sep 19 2020 01:41 PM
I installed the replacement sensor and reset the error code. No problems noted.
I decided to cut the sensor open and have a look. Here's the internal corrosion I mentioned, (CLICK). [flickr.com]
Andy
HandyAndy #1377638 Sat Sep 19 2020 03:50 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Well, that explains that!šŸ‘šŸ»
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iā€™m #2)
ā€˜39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
HandyAndy #1377651 Sat Sep 19 2020 05:42 PM
Would it do any good to slather it with silicone? Of course, that probably wouldn't help on the used one if corrosion has already gotten a foothold.
I couldn't even tell from your picture how the dang things might work. Was that a circuit board I saw? Some sort of accelerometer, I assume.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
HandyAndy #1377710 Sun Sep 20 2020 01:07 AM
That silicone might be a good idea on a new sensor, but it seems like the aluminum bushing oxidizes from the inside out. The sensors reside in a rough neighborhood, nestled under the radiator on a cross member. I'd be happy to pay a little more for a sensor that didn't corrode, but I don't think that's an option. Maybe a stainless steel bushing would be the solution?
Yes, a crusty circuit board and most likely an accelerometer. When I tested the one in the pic with my ohmmeter it was open. I'm not sure what the resistance would be on a good sensor?
Andy
HandyAndy #1377716 Sun Sep 20 2020 01:33 AM
Did the aluminum bushing split and take out the circuit board? I have a kicker mount on my boat that did that. Stainless thru-bolts with aluminum spacers. The aluminum corrosion products are like ice (bigger than the original material). Result is split bushings.
HandyAndy #1377751 Sun Sep 20 2020 02:08 PM
Yes, that's my take on the sensor failure. I suppose once they split, moisture finds its way in. The result is a short on the circuit board. It's a terrible design built for failure.
Andy
Moderated by  Bouncer, Justhorsenround, Tiny
