The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (Comediann, Pretzer46, 1 invisible), 172 guests, and 3 robots.
Forums50
Topics121,069
Posts970,532
Members43,832
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Antifreeze Leak 235 6 cyl Chevy
#1377359 Wed Sep 16 2020 11:15 PM
I am getting less than a thimble of antifreeze dripping on the floor under my 1959 Chevy PU. I have almost traced the leak to the source but... It comes down from the back of the head and above the bell housing. It runs down the right side of the bell housing and into the lip of the flywheel inspection cover and out the little hole. Initially I thought it was a freeze plug but they are lower than the leak. All I can identify above the bell housing is the head, which could have a crack. Any ideas from the group? I will say I flushed the block and replaced the radiator and had MUCH rust. I then used a rust melter in the block for 3 days and now no rust. Maybe I loosened up an old leak.
1959 Chevy Apache Stepside Truck
Re: Antifreeze Leak 235 6 cyl Chevy
59rebuild #1377409 Thu Sep 17 2020 12:45 PM
Boltergeist
Try re-torqueing the head. It can't hurt, and it just might help. Loosen the bolts about 1/2 turn one at a time, following the factory torque sequence, and retighten them. You're probably headed for a head gasket change, but it never hurts to make one last stab at a quick fix.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
59rebuild #1377431 Thu Sep 17 2020 04:48 PM
There are some core plugs (freeze plugs) behind the manifolds that can leak sometimes & run down the back of the engine. A pressure test may help locate it.
George
1956 Chevy 1/2-Ton Pickup
59rebuild #1377450 Thu Sep 17 2020 08:33 PM
Curmudgeon
If it's not leaking at the head and/or head gasket, it could be the rear freeze plug.
It's covered by the bell housing.
Picture borrowed from Deve's website.
59rebuild #1377458 Thu Sep 17 2020 10:39 PM
Also something to consider
I have a small coolant leak in one of my 235s that’s right in the middle of a flat spot on the side of the block, not even at a seam or ridge in the casting
So a defective block is possible too
Just like 59rebuild my leak was only noticeable after I cleaned the rust out the block, before that it was dry (oily and dirty tho).
-s
59rebuild #1377474 Fri Sep 18 2020 01:37 AM
ace skiver
I sealed a small crack/leak with epoxy cement/glue in the same location on my Suburban’s 1960 261 block over 15 years ago (based a recommendation/suggestion posted here).
It has not leaked since then.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
59rebuild #1377607 Sat Sep 19 2020 03:26 AM
What is the condition of this engine in terms of how long before it may need an overhaul?
If its high miles (over 60-70k miles for these engines most of the time), add some stop leak in it to buy you some time until a rebuild is in order. I did that on well worn, but great running 216 which had a 5 inch crack in the water jacket by the petcock drain. It still had a bit of a weep, but did not leave a puddle. I drove it for 20,000 miles after that with no issues.
52Carl #1377641 Sat Sep 19 2020 04:23 PM
I really do not know though it runs very well, no strange noises, good power. I bought it and restored with partial cab/engine on frame. The only thing I notice is moisture out the exhaust when it first starts up which I figured was due to being cold and moisture had settled in the ehaust.
buoymaker #1377642 Sat Sep 19 2020 04:26 PM
My leak is above the bell housing and dripping down the side, into the flywheel inspection cover.
Hotrod Lincoln #1377643 Sat Sep 19 2020 04:27 PM
I will give that a twist, no pun intended.
Page 1 of 2 1 2
Moderated by  Woogeroo
