The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (Barnfind49, coilover, 55shaker, Flatblu4748, buoymaker, 1 invisible), 249 guests, and 3 robots.
Forums60
Topics123,387
Posts995,757
Members44,653
Most Online1,229
Jan 21st, 2020
Image Posting Policy
235 Exhaust Fastener
#1377197 Wed Sep 16 2020 12:12 AM
Working on a 1953 6400 with a 235. Went to remove the lead pipe. Normally I'd split the nut to get it off. Not sure what I am looking at but does not appear to be a nut. Could be a hex shaped spacer with a 5/16 bolt (head is 1/2" not 9/16 but spacer or whatever it is is 9/16) threaded into the manifold or some type of JC Whitney latest and greatest exhaust fastener fix. Anyone know what I am looking at. Obviously don't want to break off in the manifold.
Having technical difficulties tonight will post pic in the morning.
Re: 235 Exhaust Fastener
Jack Ryan #1377224 Wed Sep 16 2020 01:48 AM
AD Addict
My 235 has studs screwed into the exhaust manifold with nuts that tighten the flange to the manifold.
Instructions “Posting images in the Stovebolt Forums” are on the left margin on the bottom of this screen.
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Jack Ryan #1377270 Wed Sep 16 2020 01:12 PM
Thank you for the picture tip, you read my mind. The stud/nut is what I expected but found something else.
Jack Ryan #1377271 Wed Sep 16 2020 01:12 PM
Thanks Phil, it worked.
Jack Ryan #1377412 Thu Sep 17 2020 01:10 PM
AD Addict
From your picture it looks like a bolt head and not a nut as you would expect. There are two possibilities. Either the PO drilled out the original stud due to it being snapped off and used a nut and bolt in place of the stud and nut or they were able to unscrew the worn stud and used a bolt in place of the stud.
If it is a bolt screwed into the original threads you best soak it with PB Blaster or Kroil for several days before trying to remove them. Even then it may be necessary to heat the area around the threaded section with an O&A torch to get them to move. If you can get them to move, don’t try to muscle them out, but instead finesse them out by soaking, tightening, loosening a little at a time and repeat.
This is what it should look like.
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Jack Ryan #1377414 Thu Sep 17 2020 01:29 PM
Victor Hot Wrench, or a Sawzall!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Moderated by  Woogeroo
