The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (LeeD, jorb, cmayna, buckaroo01, Brad Allen, 1 invisible), 190 guests, and 3 robots.
Forums50
Topics120,969
Posts969,782
Members43,804
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
How to grease a throw out bearing
#1376949 Sun Sep 13 2020 11:53 PM
Have a 65 Chevy C10 with a NP435 out of a 68 GMC. What's the proper procedure for greasing a throw out bearing that has no zerk?
Bobby
Re: How to grease a throw out bearing
Masterofnone #1376953 Mon Sep 14 2020 12:19 AM
Workshop Owner
I believe all throw out bearings are sealed bearings and cannot be greased. I've always just replaced them when installing a new clutch. It's possible that someone on here has found a way to repack them with grease, but I've never tried to, or heard of anyone doing it.
J Lucas
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
1959 Chevy Apache 31 Fleetside
1959 Chevy Apache 32 Fleetside
1959 Chevy Viking 40
My Flicker Photos! [flickr.com]
Masterofnone #1376957 Mon Sep 14 2020 12:54 AM
My Blog
Masterofnone #1376962 Mon Sep 14 2020 01:43 AM
Well okay then let me ask you this...
In the original 1963 C-10 Shop manual, it shows that there was a grease cup on the bell housing that runs down to the output shaft via a rubber hose and this cup should be greased every 6000 miles. The 68 has no such cup (and I don't remember one on my SM420....)
My 1981 international has a zerk you can get to via an inspection cover under the transmission in the area of the output shaft.
So perhaps it's not the actual throw out bearing I'm applying lube to, but the output shaft? Would you need to lube where the fork attaches to the throw out bearing?
Masterofnone #1376979 Mon Sep 14 2020 03:58 AM
Fox Offline
That’s pretty slick, Deve.
In the Stovebolt Gallery [stovebolt.com]
More pictures here [photos.app.goo.gl]
1951 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- rusted
1970 Chevrolet K20 Suburban—rusted.
1950 Chevrolet 1300- in progress to shiny.
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
Masterofnone #1376995 Mon Sep 14 2020 11:48 AM
The labor to r and r a throwout bearing is so much more than the bearing cost, just get a new bearing.
Ed
Masterofnone #1377104 Tue Sep 15 2020 03:21 AM
If you don't grease a throw out bearing, can anyone tell me why then the manual has you do it?
Masterofnone #1377108 Tue Sep 15 2020 04:07 AM
Shop Clutterist
You apply grease to the groove where the fork fits.
Gord
1954 1/2 ton 235 4 speed
Gord&Fran #1377207 Wed Sep 16 2020 12:52 AM
You are my hero! Thank you so much!
Masterofnone #1377214 Wed Sep 16 2020 01:22 AM
You also grease the recess area in the middle of the center of the bearing assembly where it rides on the tube which extends around the input shaft of the transmission.
This recess is very shallow and only needs a small amount of grease. Too much grease here will bleed out and contaminate the clutch disc.
Page 1 of 2 1 2
Moderated by  SWEET
