The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 members (klhansen, 1 invisible), 172 guests, and 3 robots.
Forums50
Topics120,898
Posts969,180
Members43,791
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 3 1 2 3
Re: hey folks rebuilding a what I think is 235 stovebolt engine
Whimpy #1377170 Tue Sep 15 2020 06:39 PM
Whimpy, did I understand the you were able to partially turn the engine by the fan? Doc.
Currently making 1954 3100 better than new
Whimpy #1377179 Tue Sep 15 2020 08:15 PM
Whimpy Offline OP
sweet thanks doug
Doc.Hall #1377182 Tue Sep 15 2020 09:03 PM
Whimpy Offline OP
I partiallty turned the engine with this strap device
Whimpy #1377183 Tue Sep 15 2020 09:03 PM
Whimpy Offline OP
Taken the fan off now going to take off the skid plate see if I can get a better angle
Whimpy #1377185 Tue Sep 15 2020 09:40 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
You want to try turning both directions.šŸ›
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iā€™m #2)
ā€˜39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
Whimpy #1377188 Tue Sep 15 2020 10:07 PM
Whimpy Offline OP
Okay sounds good thanks
Whimpy #1377189 Tue Sep 15 2020 10:47 PM
Boltergeist
Put 3-4 ounces of KROIL into all the cylinders, then wait about a week, pull the oil pan drain plug and catch what comes out. Pour it back through again. Rock the engine back and forth a little at a time and keep it soaking. Don't get impatient and try to pull the truck- - - -you could bend some connecting rods.
www.kanolabs.com [kanolabs.com]
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Hotrod Lincoln #1377191 Tue Sep 15 2020 10:55 PM
Whimpy Offline OP
Okay soubds good I've been using kroil im I also used deisel and atf the first tim but sounds good I will not pull it haha I may keep draining snd so forth get some more mystery oil and kriol , so 4 cylinders are draining through when I completely fill them up its just the 2 cylindees that are filling up with fluid and not seating through the rings
Whimpy #1377210 Wed Sep 16 2020 12:59 AM
Is that strap device on the harmonic balancer? If so, you may not want to turn the engine in that manner. You may permanently damage it. It is comprised of two pieces, inner and outer, which are separated by rubber. Turning the outer ring can tear the rubber.
A pry bar on the teeth of the flywheel would be a better plan. I just did this yesterday. The bellhousing is what you use as the fulcrum for the pry bar. works like a champ.
Whimpy #1377213 Wed Sep 16 2020 01:14 AM
Whimpy Offline OP
Okay 52carl so I take of the plate in between the oil pan and transmission to see the flywheel or take of the starter to see it ?
Page 2 of 3 1 2 3
Moderated by  Woogeroo
