EVENTS
Check in for status!
Jump over to the
Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Forums50
Topics122,169
Posts979,978
Members44,165
Most Online1,229 Jan 21st, 2020
 Hello from alberta 1965 panel van here to rebuild 😃
OP
hello folks I've got a 1965 gmc panel van with a stovebolt 235 , its been sitting awhile as it was my great grandfathers , my dad drove it 12 years ago parked it on the farm and now she's seized up , drained all fluids added some mystery oil to cylinders and what not but cannot find a good way to turn the crank from the front near the fan , ive heard you can take off the starter and pry on the flywheel but im looking for some more advice first! Anyways I've been looking at this site for awhile and I cannot wait to hear this 6 cylinder purrr
 Re: Hello from alberta 1965 panel van here to rebuild 😃
Boltergeist
Good morning, Whimpy, an welcome to Stovebolt. Congrats on the GMC panel truck.
FYI- for questions and answers the best place to ask them is in the garage forums. Members don't always come by the Welcome Centre when they log in. Your current questions would be best asked in the Engine forum, or perhaps the General truck forum.
I'll leave your first post here so members can say hello.
....but I will add that there are many ways to free up and old engine. Along with what you have done, buy a flywheel wrench that you can put on the flywheel and help spin the motor. They aren't expensive and you'll use it more than thank you think. you can pry on the flywheel with a big screw driver but you don't want to brake anything!!! Some folks use 50/50 mixture of transmission fluid and diesel fuel and many other concoctions. Its a slow process but can be done with patience. I will add that I had a 261 engine that I ended up pulling the head and "pounding" on the pistons to get it freed up but hope you don't have to do that.
I'd suggest starting a thread in the "projects forum" so we can all follow along...in addition to asking questions in the garage forums. Just take your time, look around the site here and get familiar with things. We are all here to help.....and be sure to watch for others from your area as there are quite a few here.
Moderator - The Electrical Bay and Rocky Mountain Bolters
Welcome to the 'bolt. please post a couple pix of your project.
Another quality post.
Real Trucks Rattle
Workshop Owner
Hello Whimpy,
Alvin is correct, you'll get more and quicker replies by posting in the appropriate forum.
That said, if your van has a manual transmission you can put it in 1st or reverse gear and slowly try and rock it forwards and backwards.
Welcome to the Stovebolt.
J Lucas 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWB 1959 Chevy Apache 31 Fleetside 1959 Chevy Apache 32 Fleetside 1959 Chevy Viking 40 My Flicker Photos! [flickr.com]
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Welcome to the Stovebolt madness. There is no cure!  ‘65 GMC should not have a 235. If it does, somebody has been monkeying with it.
Martin '62 Chevy C-10 Stepside Shortbed (Restomod in progress) '47 Chevy 3100 5 Window (long term project) ‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) ‘39 Dodge Businessmans Coupe USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one! Support those brave men/women who stand the "Thin Blue Line"! Hug a cop!
OP
3850817 is on my bloxk says its 230-250 3859381 is on the headers idk if you can help me find out what it is then ?
OP
That is awesome I will be trying the rocking method then !
Welcome ,wouldn’t hurt to take valve cover and side cover off and put a little mystery oil by valves and lifters
OP
Welcome! This place has a heap of great information. Check out the tech tips too!
1950 Chevrolet Model 1314
